Clear Coat Renault Aluminium castings
Results 1 to 9 of 9
Like Tree6Likes
Thread: Clear Coat Renault Aluminium castings
    Member JohnnyAfrica12G's Avatar
    Jul 2015
    Pyalong Victoria
    59
    Default Clear Coat Renault Aluminium castings
    Hi Guys, The 365-00's housings from the 12G have had a light blasting and look amazing, the next question is what to coat them in to prevent oil and grease etching in and to preserve this look. I noticed that both KBS & POR have a product, has anyone used either or do you have alternative suggestions??? Thanks in advance peeps
    1000+ Posts Dano's Avatar
    Apr 2012
    1,448
    I have coated all the aluminium bits for the 404 in POR Glisten. It has a high gloss finish, but the aluminium looks a little darker when it dries. Cannot comment on the long term results, as the car is not finished yet. See photos below. I have been assured that it will not yellow or peel, under normal engine running conditions (?). What I do like about it, is it is bush-able and the coating is self-levelling.
    Dano
ID:	94831Click image for larger version.
ID:	94832Click image for larger version.
ID:	94833Click image for larger version.
ID:	94834Click image for larger version.
    Boonah Qld
    2,636
    I have also used Glisten. I have an alternator done in it years ago I'll find it tomorrow and see how it has lasted.
    Jul 2015
    Pyalong Victoria
    59
    Thanks for your post
    Jul 2015
    Pyalong Victoria
    59
    Also wondering about heat, oil grease resistance???? Thanks for your effort
    Boonah Qld
    2,636
    Sorry about that. I'll try and remember to do it tomorrow. From memory I think normal engine bay heat is ok. This is the Glisten Product sheet.
    Glisten PC High Performance Clear Coat
    Mar 2013
    olinda victoria australia
    765
    Bugger. Hadn't thought of this. Good idea
    Now going to have to take it all apart and start again
    Wasn't aware that one could get clear Pore. Have used the black stuff pretty liberally and love it - sticks like shit to a blanket on sand/soda blasted steel.
    Andrew
    Quote Originally Posted by Dano View Post
    Dano
    Apr 2012
    1,448
    Andrew, had all the aluminium wet blasted. The finish was amazing.
    Johnny, As for grease, any grease or oil I've gotten on these parts so far has just wiped off. Being two pack it is fairly durable.
    Boonah Qld
    2,636
    I checked the alternator and the clear is very shiney. There are a few chip marks that have since got a bit of corrosion. The aluminium seems grey undernieth the clear, rather than the shine I know it originally had. Oil and dirt just wipe off. However over that period of time aluminium left with out a coat would look very dirty and grey anyway. At least this wipes clean and looks ok.
