Auto warning light has come on - do i need to get car towed?
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By COL
  • 1 Post By REN TIN TIN
Thread: Auto warning light has come on - do i need to get car towed?
    Sep 2016
    Cairns
    4
    Icon5 Auto warning light has come on - do i need to get car towed?
    Hi can anyone help pls ive got a 2006 renault clio auto and the auto warning light has come on. The gearbox jumped from d to 2 yesterday on the highway. it is ok around town. should i get it towed to dealer? i am 90 klms from a dealer so a bit worried about driving it. thanks for your time everyone. michele
    11,310
    Lots of viewers but no comments.... I honestly don't know the answer, our similar age Scenics being manual, but would share your hesitation in driving it. I'd start by ringing the dealer and maybe Renault . I know dealers get bagged a lot but asking is cheap and sometimes they do actually know.
    It would be a flat bed truck not a tow perhaps - RACQ member?
    You're some way out of Cairns I take it?
    Best of luck with it.
    Probably the competent responses will flood in now....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,346
    Can you explain the jumped from D to 2 on the highway bit, was you just cruising along or did you apply the go pedal asking for more acceleration?
    Does the drive properly now? does is shift up through the gears like it did before this episode?
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    11,310
    Ah, that worked. Another reply within minutes!!!
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,346
    I'm like you John not sure what to advise in this case.
    Maybe a few more details and others will help out.
    JohnW likes this.
    Regards Col
    1973 Alpine A110
    9,339
    A first cheap test that can help avoid a lot of potentially needless worries (and second guessing from us) and can't harm anything is to check the transmission fluid level. Report back and we can try to dig deeper.
    ACHTUNG ALLES LOOKENPEEPERS
    Brisbane/Australia
    2,207
    Jumping from D to 2 sounds like it went into limp mode although that is from D to 3.
    There are a multitude of reasons why this could occur from low fluid to overheating (on the highway in Cairns in summer, not farfetched) to problems with the solenoids, bands, etc.
    Is the gearbox warning light still coming on when restarted now that the car has been rested?
    If the light is off now and it is heat related then it is likely to be okay now that it's cooled but it could occur again in similar circumstances. For peace of mind you might have the gearbox checked but there's likely no urgency.
    If the light is still on have the gearbox checked by a competent repairer.
    Your dealer will be able to connect the computer and read the error codes and pin point the issue.
    Ren
    frenchtranstech likes this.
