Scenic RX4 starter motor removal tips
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By David Cavanagh
Thread: Scenic RX4 starter motor removal tips
    Feb 2016
    Port Macquarie
    8
    Default Scenic RX4 starter motor removal tips
    Hi guys,
    I just replaced my clutch and seem to have now developed a problem with the starter motor. Blowed if I'm taking it all apart again! I have read that it's possible to get the starter motor out without removing driveshaft and exhaust manifold.
    Has anyone got experience with this or helpful tips about getting it out?
    Dave
    Feb 2001
    Romsey, Victoria, Australia
    4,600
    Quote Originally Posted by dnhdennis View Post
    Hi guys,
    Dave
    Start from the tail lights and work your way forward.
    Your on the right track, driveshaft, manifold. Bugger of a job.
    27of85 likes this.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    5,671
    Dave, what's the problem? Before you go too far, make sure you've replaced all earths to the engine and gearbox securely.
    2003 PEUGEOT 206 GTi
    Feb 2001
    4,600
    2WD is quite easy. 4WD, nuh don't volunteer for that one.
    HONG KONG PUGGY likes this.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    1000+ Posts cav91's Avatar
    Kyneton, VIC
    2,174
    Don't get me started on rx4 starter motors. I spent half a day on the ground in the yard pulling out the driveshaft. To find that after all that it was still quicker to go and remove one from a complete 2wd.
    406 D8 V6 manual
    5,671
    I was thinking the gearbox earth may have been removed and not replaced, and possibly enough current would flow to make the solenoid click even without it, making it seem like the starter.
    Feb 2016
    Port Macquarie
    8
    Thanks to all replies.
    To be clear, the starter was working and the engine running so electrics are fine, but a bit of a nasty mechanical grinding so turned it straight off again.
    I found that removing the lowest part of heat shield off the manifold (easy enough) gave enough room to drop the starter down through the gap where the RH drive shaft is now the only thing holding it in. Starter and flywheel teeth look ok so maybe it was just a return spring or alignment glitch (when removing gearbox we found there was only two bolts in the starter rather than 3). So RH driveshaft will come out and then I can properly check the starter motor.
    Fingers crossed...
    Feb 2016
    Port Macquarie
    8
    he Turns out the wrong clutch kit had been sent to me (from the UK... via eBay - won't do that again), and I didn't notice the difference in the pressure plate. Took the gearbox out and realised the mistake, so ended up putting the old pressure plate back in with new friction plate.
    Nov 2002
    Yarranilba, Queensland
    2,757
    Honestly, I don't envy you at all.
    The starter on an Rx4 would be the toughest replacement I have endured in 35 years of tinkering with cars bar NONE.
    It is a bitch of a job.
    Yes, driveshaft and manifold need to be removed....crappy to say the least.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
