R16 rocker cover spark plug tube seals.
Results 1 to 9 of 9
Like Tree5Likes
  • 4 Post By alexander
  • 1 Post By driven
Thread: R16 rocker cover spark plug tube seals.
    Banned
    sydney, australia
    11,321
    Default R16 rocker cover spark plug tube seals.
    David C tells me the seals which sit around the spark plug tubes, under the rocker cover, are not available.
    which certainly doesnt stop oil leaking out!
    anyway, i have a solution which others may find useful.
    *i found that Bunnings sells a variety of EPDM products ie the same thing O rings are made from
    *i used 9mm spongy EPDM tube, cut and glued into a circle with super glue
    *this works with the non spongy EPDM as well, for making O rings of any size.
    *i used these O rings instead of the worn out spark plug tube seals and it appears to be a/ completely successful and b/ very cheap.
    JohnW, Sarosa, CXVingtCinq and 1 others like this.
    Mar 2015
    Geelong Australia
    62
    I may have some . Will check on Monday. David
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,380
    Nice solution, thanks for sharing.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    3,311
    Mecca Parts have them available for 12.26 euros each part no MP 1119 They are different in appearance to the original.
    .2010 Holden Commodore Ute
    Banned
    sydney, australia
    11,321
    haha well in that case you can save yourself EUR 12.20 and the postage!
    1000+ Posts driven's Avatar
    Apr 2005
    1,105
    Default EPDM is not suitable to use with Motor Oil
    Sorry Guys,
    It will dissolve and get transferred through out engine
    The best seals are Viton Rubber
    Take it out ASAP
    Always check the charts when changing materials
    Rubber Chemical Resistance, Rubber Chemical Compatibility, Page 4 - Mykin Inc
    BenoniJap likes this.
    7,934
    Viton is the best because of its high temperature tolerance, but nitrile is good as well as far as organic compounds are concerned, i.e. it will not dissolve in oil, etc. The temperature (outside its range) will kill it eventually. Nitrile is of course cheaper.
    This is something to consider when choosing oil seals as well. You can get most oil seals (camshaft, crankshaft, etc) in normal compounds, and they'll be cheaper, but Viton won't (or not much). And sometimes you can only get Viton in OEM parts. Just check when choosing stuff so you don't have to take the gearbox off again after 200km because you used the wrong rear main seal material.
    ACHTUNG ALLES LOOKENPEEPERS
    Ipswich, Queensland.
    1,788
    Meca parts have the correct seal MP 0338.1 for 2.35 Euro each. It is one of their "NEW" parts.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    Banned
    sydney, australia
    11,321
    Sorry Guys,
    since these posts i have had a piece of EPDM soaking in a jar of motor oil.
    it hasnt dissolved, or obviously changed in its consistency in any way.
    heat and used motor oil might make a difference, but as the car hasnt been used in the interim, i cant report on that as yet.
