Succumbed to Modernisation - Page 2
Page 2 of 3 First 123 Last
Results 26 to 50 of 59
Like Tree13Likes
Thread: Succumbed to Modernisation
  1. #26
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,413
    Not sure what was in your hazard flasher kit Kevin, but here is a schematic of a kit available from AES
    http://www.autoelectricsupplies.co.u...ng_diagram.jpg
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  2. #27
    4,032
    Armadillo, perhaps.
    COL, I only got what was in the last pic. Looks like I'll need to add a separately relay/flasher can for the hazards? I thought maybe the switch did that.
    KB
  3. #28
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,413
    The switch looks to small to contain a flasher unit.
    You may want to check with a multimeter the operation of the switch to make sure that you have the connections correct.
    You will need something similar to these flasher units
    hazard flasher unit | eBay
    Regards Col
    1973 Alpine A110
  4. #29
    17,438
    Armadillo, perhaps.
    Actually, provided your existing flasher is rated to the load of of total lamp load .
    IIRC The entire circuit can be concocted using a single pole 15 amp switch and three 10 amp diodes. I need to figure out the circuit again.
    It's far more reliable than multi pole switches because there is less to go wrong.
    At worst you need to replace you flasher can with a heavy duty "transistor" unit that flashes at the same rate regardless of load current.
    IMO the less relay and switch contacts additional to the OEM wiring the better.
    JohnW likes this.
    Mutual Respect is Contagious
  5. #30
    4,032
    I have something similar to the Bosch unit at the top of that eBay list already in the drawer.
    I'll have a play with that first based on the diagram COL provided.
    I'm hoping to get the wiring tested and sorted before I put the dash back in, then it becomes much harder access wise.
    KB
  6. #31
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,413
    Regards Col
    1973 Alpine A110
  7. #32
    9,721
    I reckon the screen GPS is really good, but as a supplement to the real one. I reckon the real one's accuracy on mine is as follows, approximately of course):
    Indicated (mph) Actual (kph)
    45 60
    50-55 70
    60 80
    75 100 (4,000 rpm in top gear)
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Peugeot 306 XT 1995 (daughter's)
    CitroŽn CX Pallas 1980
  8. #33
    4,032
    My little bench test rig proved the hazard switch is just that, not a flasher control unit.
    A narva flasher unit I have worked but flashed the one globe I had rigged up too fast. The "Bosch" unit I could get to click but not flash the globe. Might have to hunt down another flasher can to try.
    KB
  9. #34
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,413
    Kevin you will need more than one globe to make the flasher flash at the right rate (what you mimicked was like a blown globe in the car). The globes need to be 18 watt and to bench test the flasher that you have you will need 4 globes.
    Regards Col
    1973 Alpine A110
  10. #35
    9,721
    Do you have an electronic flasher or a conventional thermal unit? The thermal ones depend upon current for speed but the electronic ones are, if I understand it correctly, not current dependent, so maybe would work for you at the right speed?
    Renault 4CV 1951
    Renault R8 1965
  11. #36
    4,032
    The indicator flasher is the std Renault one.
    The other two I refer to are both the electronic type - One is a Narva brand; the other is an unnamed Bosch clone similar to the top one in the link COL posted. The Narva was brand new I bought a number of years ago for my sister-in-laws' car, but turned out to not be the problem so it was put in a drawer and forgotten. The "Bosch" unit I don't recall where it came from - perhaps it was an indicator flasher can off a car I have dismantled - maybe it doesn't work.
    I suspect COL is correct in that my test rig was failed. The first time I used an R8 front sidelight as the globe, the second time the globe off the back of the dash for the indicators both would be much lower wattage than COL recommends. I think I will wire up the two indicator wires to the indicator switch wires on the actual car; then wire the Narva flasher and my new switch using the schematic COL provided but give it temporary power using my bench power supply - I don't want to reconnect the battery while the dash is apart and wires hanging everywhere. If the lights flash correctly, I'm home and hosed and the wiring (which needs to be there anyhow) is partly done already. If it still flashes too fast, then maybe it is a matter of trying a few flash cans.
    I can't progress anything else until the pin for the wiper motor is machined; and I get the dash and cable back anyhow so I may as well tinker with this while the dash is out.
    KB
  12. #37
    7,990
    Another option is to just wire in the hazard switch in parallel with the indicator switch on the existing flasher relay you have. From experience, this will make your flasher go twice as fast, because your old unit is load dependent. Rob's suggestion takes you out of this pickle. Get a new flasher unit load independent and you're set.
    Or, just use one of your spare relays in independent of the existing one as you plan. You can still connect the dash light output to the existing one (if the hazard switch you have doesn't have one, or you want both to operate when hazards are on).
    PS. I wouldn't machine the shaft of that wiper motor. Much easier to adapt the lever, or make a custom one that replaces the original. Actually I would take the latter option because that would allow immediate swap back to original, you know, just in case.
    ACHTUNG ALLES LOOKENPEEPERS
  13. #38
    4,032
    Schlitzaugen,
    I'm not modifying the wiper motor shaft. The new motor has a thicker shaft and therefore a bigger nut. The old shaft also had a key way arrangement which the new one doesn't. I looked at modifying the original piece that bolts to the shaft, but decided in the end it would be easier to make up a new one as a replacement. Part of the difficulty is that the nut on the original is quite small and fits into a recess in the rubber. The larger nut that fits the new shaft, is bigger and while it fits in the recess, does not allow a spanner or socket access to tighten. There is not enough "meat" to drill it out.
    This "plate" for want of a better word, has a pin with a circlip groove which then connects to a smaller arm which in turn connects the wiper rods that ultimately turn the shafts. Again, this was something that needed to be done on the R12 conversions in the past also.
    KB
  14. #39
    7,990
    I think making a new plate is the way to go.
    Some pictures might help with your conundrum.
    What size are the old and the new shaft nuts?
    I see in your picture the new motor installed, with the shaft poking through the firewall. To me it sort of looks like a M8? shaft? If that is the case, you can find undersized nuts, most likely on japanese cars (most of the time these are serrated flange nuts, so it's a bonus on condition the flange is small enough to go through the recess).
    Failing that, I would look at a long nut (they are sold as "nut extenders" or "shaft extenders"), but this assumes you can have it poke out of whatever arrangement you have. They are long enough that you can trim them to whatever size you need. If need be, you can machine a shoulder at the end where they have to go through the flange. Have a look at Bunno's or similar.
  15. #40
    4,032
    I've actually received the new plate - the pin was made today as a foreign order, and attached to the plate I'd already fabricated. I'll post some pics tonight, it won't let me do it from work. So I'll hopefully be putting that in tonight.
    Not a bad suggestion on the extended hex nut - bit like a manifold nut I imagine. I don't think it can extend too far out though without interfering with the secondary arm that attaches via circlip. Hopefully I won't need it now anyhow with the new plate being completed.
    KB
  16. #41
    4,032
    So, this has been put on the back burner while I was overseas on hols, but back into it now.
    Just before I left I received a new speedo cable (new inner and outer and reusing the gearbox end ferrule) and the refurbished speedo. Not cheap at $880 but good to retain the original equipment. The wiper motor is in and tested. The sweep of one arm is shorter than I would have liked, I may need to muck around with the lengths of the connectors later to improve but it's working for now.
    The headlight alert is in. The hazards have been tested but I need to complete the wiring and then put the dash back in.
    I ended up using the std flasher can. On the indicator switch there is three wires, a pink or red and blue for left and right indicators; and a grey wire in the centre that connects to the flashing power supply of the can. I just ran three wires from these to behind the dash and then used a plug to connect these to the three respective wires of the switch.
    Hopefully it will all be back together and working over the weekend. The dash reinstall being the hardest part!
    KB
    KB
  17. #42
    7,990
    Shit almighty. 880$ for a speedo cable and a gauge refurbish?! I reckon you won't make a huge profit if you ever sell the car.
  18. #43
    9,721
    Doesn't matter. You don't sell good R8s.
    Renault 4CV 1951
    Renault R8 1965
  19. #44
    9,721
    Sounds good. I've never, ever pulled the dash on mine. I probably should, to sort out the rat's nest of wiring that has "evolved" over the years. Ditto the 4CV!
    Has your R8 ever broken down and needed hazard flashers?
    Hope the holiday was good.
    Renault 4CV 1951
    Renault R8 1965
  20. #45
    It's how I roll...Brisbane
    31,978
    KB,
    I hope you bought me back a Hawaiian shirt..
  21. #46
    4,032
    Quote Originally Posted by 59 Floride View Post
    KB,
    I thought you were well stocked already?
    John, only once. Heading to the Junee muster when the push on fuel line came loose. But I thought if it's all apart, it's a good time to do it.
    JohnW likes this.
    KB
  22. #47
    4,032
    I'm pretty much resigned to making a 50% loss. My only hope is if non-gordinis start making a huge surge in value due to their apparent rarity!
    KB
  23. #48
    9,721
    We live in hope..... Our R8 costs, amortised over 43 years, are probably OK.
    Yours would be one of the very best original R8s I've ever seen, that is for sure.
    Renault 4CV 1951
    Renault R8 1965
  24. #49
    9,721
    Renault 4CV 1951
    Renault R8 1965
  25. #50
    4,032
    So it's all back together and working.
    The only downfall to my plan is that the hazards only work when the ignition is on (as they are powered by the indicator can). I'll have to think about how I can wire a discrete switch so that it takes ign 12v+ for most of the time and switch to fused constant 12V+ if and when the hazards are needed.
    The headlight alert also buzzes slightly when the car is running (and the door closed). Maybe a small bit of rubber on the door might help depress the door switch further in - perhaps to compensate for a worn switch.
    Attached Thumbnails Attached Thumbnails Succumbed to Modernisation-dscn2885.jpg   Succumbed to Modernisation-dscn2884.jpg
    KB
