R12 Alternator Upgrade - Page 2
Page 2 of 2 First 12
Results 26 to 29 of 29
Like Tree6Likes
Thread: R12 Alternator Upgrade
  1. #26
    Oct 2014
    Windsor 2756 NSW Australia
    421
    Another good reason my cars have battery isolation switches. Makes it very easy to avoid any zaps and sparks when working on or near those components.
  2. #27
    Brisbane/Australia
    1,802
    I love that. Disconnect the battery when changing the oil filter.
    There must be room somewhere for a fuel filter on the suction side of the pump. ??
    It's no big deal to disconnect the battery in a 12. The battery terminal has a wing nut so one doesn't even need any tools.
    There are no computers that need PIN numbers and in mine there's not even a clock or stereo to reset.
    The joys of simplicity.
    Regarding the fuel filter, there's a solid fuel line running from the rear subframe to the inner front guard.
    There's about a 2 inch gap between the pipe and pump in the front and probably slightly longer in the rear between the pipe and fuel tank. The back is out, I don't want to be crawling under the car to check or change a fuel filter.
    I could possibly cut down the solid pipe in the front but then I'd have to mount the filter under the front guard.
    It's not ideal but it came from the factory like this in 1973 and if it was good enough for Renault back then it's good enough for me now.
    Ren
    "I cannot help but notice that there is no problem between us that cannot be solved by your departure."
  3. #28
    Brisbane/Australia
    1,802
    One small issue has arisen with this set up.
    The old V-pulley that was transferred from the old R12 Bosch alternator to the Mitsubishi alternator has a much larger diameter than the previous ribbed-belt pulley on the Mitsubishi hence the alternator runs at a lower speed at idle than it was designed for.
    Still pushes out around 13.8 volts at idle with no load (engine only) so is enough.
    At idle with load, (i.e. lights, brake lights, etc.) it drops to about 13.2 - 13.4 so is still charging.
    At speed say, 3000RPM, it's pushing out around 14.1 - 14.2 volts so not a problem.
    One thing found is the heater fan is drawing what I consider huge currents when on high speed.
    It's about 10 amps which I think is high (I'll have to check the spec in the manual).
    Ren
  4. #29
    7,934
    Nah, 10Amps is just enough to actually move some air. I would be worried if it used less, for that would mean it's not actually doing anything.
    Check the fan fuse for rating.
    ACHTUNG ALLES LOOKENPEEPERS
