Scenic Door lock problem
Results 1 to 3 of 3
    Aug 2013
    Australia
    2
    Default Scenic Door lock problem
    Hi all,
    I have the dreaded door lock will only unlock sometimes syndrome lol unfortunately itís on the driverís door
    I have been told the solenoid/actuator can be replaced within the locking system, on the other hand I have also been told it's all one unit, I had a look today but for the life of me I could not see it correctly although I removed the door lining I could not completely remove the lock, I also canít find any diagrams/instructions on how to remove the locking system from the doorÖ
    Any input would be greatly appreciated
    2002 Scenic
    Brisbane/Australia
    2,067
    Hello rjcdani,
    I can send the appropriate pages from the Haynes manual if you haven't got them already.
    Doesn't give much detail but might help.
    The pages are too big to attach (<100K).
    Also attached is the RH door diagram from the Renault NT8156A manual.
    This is the LHD version but the lock should be the same.
    Might be of some use.
    315.pdf
    Ren
    Aug 2013
    Australia
    2
    Hi Ren,
    I have sent you a message.
    Rob
