Compression Ratio Calculations ? 1289cc
Results 1 to 13 of 13
Like Tree12Likes
  • 1 Post By robmac
  • 1 Post By Kim Luck
  • 1 Post By robmac
  • 2 Post By Frans
  • 1 Post By geckoeng
  • 2 Post By Toolman
  • 1 Post By Sunroof
  • 2 Post By Sunroof
  • 1 Post By Frans
Thread: Compression Ratio Calculations ? 1289cc
    Feb 2012
    Vista SA
    986
    Default Compression Ratio Calculations ? 1289cc
    Is there a way of calculating your compression ratio working backwards from what the compression is ???
    Like: 180psi or that close to it in all 4 cylinders, and yes, the head was reduced in thickness before fitting.
    Look forward to hearing from a physics PHD.
    Phil
    19,041
    Assuming atmospheric pressure in uncompressed state, 140 / atmospheric pressure should give an approximation.
    140/ 14.7 (approx at sea level )= 12:1 approx ? Does that seem correct ?
    I'm not a physics Phd, so I'll wait for someone who is to correct me
    R8philSA likes this.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,953
    I suspect that there may currently be a shortage of PhD wielding Froggers about today so I'll give you this:
    Engine Compression Ratio (CR) Calculator
    Fellow Frogger! keith mcelroy's Avatar
    Sep 2004
    ballarat
    249
    I think the difficulty with approximating from compression readings and atmospheric is tjat the cylinders do not necessarily completely empty to atmospheric while the compression is being measured. Thus I think you would calculate an over estimate.
    19,041
    Quote Originally Posted by keith mcelroy View Post
    I pondered that too, but figured an inlet valve opening must give a starting pressure close to atmospheric.
    And I'm in furious agreement this method is only an approximation, the only accurate way is measure CC volumes.
    1000+ Posts Frans's Avatar
    Auckland
    1,487
    My worth.
    You cannot do it. Years ago I built and patented an analogous variable cam engine and one of the things that limited my small duration/small overlap/hi torque/lowRPM profile on the lobe was compression ratio. The less/smaller the overlap the higher the compression.
    So what are your overlap and over and above that what is your valve clearance. I had to do an experiment for my Variable cam project and this is the figures that popped up on the engine that I used for the patent demonstration, a 1800 SOHC BMW 4 cyl engine.
    Rocker gap 0,2mm: Comp. 1150kpa: Intake vlv opens 24deg BTDC
    Rocker gap 0,3mm: Comp. 1270kpa: Intake vlv opens 12deg BTDC
    Rocker gap 0,4mm: Comp. 1350kpa: Intake vlv opens 5deg BTDC
    Rocker gap 0,5mm: Comp. 1350kpa: Intake vlv opens 2deg BTDC
    You can see how the pressure goes up on the same engine but with different rocker clearances.
    What I am trying to say is that I think it will be very wrong because you can alter your compression reading by increasing the rocker gap. There is a huge difference in static CR and running CR. You are trying to calculate the static CR, however you are trying to calculate it with running CR figures.
    Open for discussion on this one.
    Frans.
    R8philSA and robmac like this.
    Old enough to know better
    Young enough to do it anyway.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,643
    Frans you are right on the button here, with regards actual compression tests. The whole thing has too many variables.
    Actual volumetric compression ratio (CR) can only be worked out by measurement, as in Kim Luck's link.
    As for 180psi I would suggest Phil has his valve clearances a bit too loose.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Feb 2012
    Vista SA
    986
    Thank you all that replied, really given me something to contemplate.
    Phil
    Phil
    Mar 2015
    Geelong Australia
    67
    A couple of thoughts that I had on the subject are that the compression pressure on cranking are directly related to the efficiency as a pump and subject to port speed , valve timing , cranking speed on the starter etc . The higher compression reading usually indicates good low torque and good ring sealing .
    By filling the combustion chamber with a known quantity of oil at bdc and rotating the crank to tdc , catching and measuring the expelled oil will give you what you are looking for [ assuming the spark plug hole is the highest point and there is no trapped air ]
    Have fun with that . David
    Sunroof and R8philSA like this.
    Boonah Qld
    2,521
    Quote Originally Posted by Toolman View Post
    Very clever. Logical when you think about it, but who else did?
    7,446
    Always remember, the compression stroke doesn't start until the inlet valve closes.
    You can buy such a gadget as Toolman describes. Scrutineers use them to make sure race teams aren't cheating with compression ratios.
    Boonah Qld
    2,521
    If we have an engine, at BDC that has a swept volume of 900cc in the cylinder and a combustion chamber volume of 100cc, then this volume is reduced to the 100cc of the combustion chamber at TDC this would be a compression ratio of 1000:100, or reducing it fractionally, a compression ratio of 10:1. Courtesy Wikipedia.
    You already know the swept volume IE stroke by bore in cc's. Therefore given that the spark plug hole is at the top and no air trapped as Toolman says then surely all you have to do is set the piston at TDC on a firing stroke and measure the oil that it takes to fill just to the spark plug hole. (Allow a little for plug protrusion perhaps.) Isn't that the combustion chamber volume, and therefore the ratio can be calculated? Use a syringe to suck out the excess oil before trying to start the engine though. Or have I got this all wrong?
    R8philSA and J-man like this.
    Auckland
    1,487
    Remember that at BDC the intake valve is still open, and will remain open until about 30 degrees ABDC, so you'll have to catch the oil that runs into the intake port as well.
    Frans.
