C5 Steelies ???
Results 1 to 22 of 22
Like Tree5Likes
  • 3 Post By geckoeng
  • 2 Post By rubyalpine
Thread: C5 Steelies ???
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,643
    Default C5 Steelies ???
    OK, seeing I am not going to get a set of Gordini steel wheels, I will go in a different direction.
    I want tech information of Citroen C5 "Steelie" wheels, and some pictures of outside and inside. What sizes do they come in.
    Does anybody have 5 the same, for sale???
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    7,446
    One size, 15 x 6, 18ET. There are two styles of bolt holes however, flat seat and tapered seat. The flat seat type were recalled.
    Attached Thumbnails Attached Thumbnails C5 Steelies ???-c5-tapered-seat-wheels.jpg
    Feb 2005
    rosevale/tasmania
    2,745
    Just what is the intention here? The offset of the C5 rims looks wrong. If one wanted to craft steelies for a rear-engined Renault, then are you after original width & 15" or wider & 15" or would you consider another diameter & so on?
    cheers! Pete
    Perth, WA
    1,643
    Hi Pete,
    My intention here is to just see what they look like in standard form. Gives me Ideas. Light bulb!!!!1
    By the way the last person to ask me what my intentions were, was my Father In Law, with regards to his daughter. Little did he know ...... !!!!
    Ray
    David Cavanagh, Paul T and BIGRR like this.
    Ray geckoeng
    Feb 2001
    Romsey, Victoria, Australia
    4,819
    We've got a full set if your interested.
    Surprisingly big sellers, usually for clubman type cars.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    634
    Hi Pete,
    I have often thought with the uniqueness of the R8/10 wheel (3 stud) that why has not anyone considered a hub conversion to a more conventional 4/5 stud hub set up as the number of alloy wheels available (say early Torana XU1 / SLR 13") would be far cost effective than paying $2000 odd + transport from France (ie Mecaparts)?
    I suspect this would have meant a specially made hub to suit the stub axel setup, but with modern CNC and lathes this should be easily done or is it a ADR issue?
    Maybe someone has been down this path before and can probably enlighten me?
    Angelo
    10,754
    Quote Originally Posted by R8 Dream View Post
    I have often thought with the uniqueness of the R8/10 wheel (3 stud) that why has not anyone considered a hub conversion to a more conventional 4/5 stud hub set up as the number of alloy wheels available (say early Torana XU1 / SLR 13") would be far cost effective than paying $2000 odd + transport from France (ie Mecaparts)? I suspect this would have meant a specially made hub to suit the stub axel setup, but with modern CNC and lathes this should be easily done or is it a ADR issue? Maybe someone has been down this path before and can probably enlighten me? Cheers Angelo
    I reckon there was a thread, or at least a mention on a thread, of exactly this, perhaps 5+ years ago? It's been done, that is for sure.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    6,248
    Pete, they're actually lightweight aluminium; only about 5 kg, hence the interest.
    cheers! Pete
    2003 PEUGEOT 206 GTi
    4,366
    Waynerenault in WA did exactly that (redrill for four stud or an adaptor of some sort) on his green machine.
    The car ended up going to scrap after a few changes in ownership as I recall.
    KB
    10,754
    That's the one KB. Thanks. That was the early R1132 I gave him I fear..... However, I do have the key early-type bumpers as a spare for my R1130 and it gave me a set of black and white genuine number plates for the 4CV!
    Renault 4CV 1951
    Renault R8 1965
    Aug 2011
    BÝmlo, Norway
    46
    The C5 steelies are really nice. Ive had a few sets in possession and have used them both on my 106 Rallye, Xsara VTS and both my Berlingos. Actually I also considdered butchering a set to make 15" bimetal wheels for my R8. Unfortunately the inner diameter of the rim were a few mm to small for the R8 steel centre.
    6,248
    I've always liked holey steelies for some reason. My black 206 would suit a set of those black ones I reckon. Plus they're the same size as the Ouragans, but with 10mm different more positive offset which may not be a problem.
    Feb 2005
    rosevale/tasmania
    2,745
    Quote Originally Posted by Reidar View Post
    Surely a too small rim is not an issue as one just cuts down the centre diameter by that amount. A too large rim on the other hand . . . . .
    Feb 2005
    rosevale/tasmania
    2,745
    Goodness! I've not before heard of an alloy wheel made to look like a steel one.
    6,248
    Gee I'm a nob. They're an inch smaller than the 206 wheels.
    Feb 2005
    rosevale/tasmania
    2,745
    I've passed comment on the widening of standard 4x15" wheels in the related thread in the parts-for-sale/wanted section. One thing that I didn't say there is that 150 m is a common PCD for 6-stud commercial wheels.
    Before simply reinforcing the standard centres as explained in that other forum post, I considered converting to 6-stud (& had a jig made up using an old R12 hub). Given the strength of the centres of commercial wheels, I imagine that one could just use 3 studs & holes & fit dummies to the other 3 but no doubt the relevant authorities would freak out.
    cheers! Peter
    Aug 2011
    BÝmlo, Norway
    46
    The rims of the 5x15" and 5,5x15" of the old ID/DS fits perfectly on the R8 centers. I have made two such R8 wheels in 5,5x15. Another option is the rims from the 6,5x15" of the newer type Berlingo. A bit wide for standard arches though... I guess there is 6x15" options also but I have found that the inner diameter of the rim is 3-4mm to small on most 15" steel wheels.
    Perth, WA
    1,643
    Reidar you are great !!!
    OK I need to find somebody in the West who will have some 15x5 or 5.5 Citroen wheels that I can look at and measure. What Reidar says is also true with Berlingo, as I have seen them with 175/65/15 tyres on which looked a proper fit so would be a 5.5, so Berlingo wheels as well.
    Thank you,
    Ray
    Ray geckoeng
    634
    Hi Reidar
    Any photos on what they would look like on and off the R8?
    Angelo
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    474
    You can have practically any size wheel you like on you R8/R10 just by buying the size rim you prefer and then have a wheel maker laser cut a centre to suit and weld it in, in place of the original centre.
    I drew my desired centre patern on a piece of hardbord with a school compass, took it to the wheel man and he cut the centres accordingly.
    Henry
    forzamacchi and Graelin like this.
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
    Aug 2011
    BÝmlo, Norway
    46
    I have some pictures from the wheel project and other R8 stuff in this thread. Its in Norwegian but it might make som sense if run through google translate:
    Trim-4-eldre.com Forum
    I never got to try the wheels in real life. Suddenly I had too many other alternatives. CMR steelies picked up in France, Cosmic alloys and standard Gordini 4,5x15.
    Boonah Qld
    2,521
    Some really great photos.
