R8/10 front wheel bearings
    Oct 2012
    600
    Default R8/10 front wheel bearings
    Forgive me if this has been discussed before but has anyone used a standard 30204 bearing for the inside and made up a 5.5mm spacer for the back. I can get the correct one from Mecaparts, at a cost. I'd still need the seal and the backing cup, or are they standard parts? The outside bearing is standard 30203.
    Oct 2012
    600
    Answering my own question, the seal is a standard part. The cups can be bought separately from mecaparts, if they ever get back to me.
    11,193
    I don't immediately see why not. The question is why? There is a bearing designed for the job and available after all. Not the cheapest, I'd concede.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Oct 2012
    600
    I'm trying to limit my mecaparts order. If I can get the part here at a reasonable price then I will.
    It also gives me some flexibility in the spacing for my brake design.
    11,193
    Fair enough. Sort of presumed that. Hopefully someone who has actually tried it will respond.
