R8 Door latch spring
Results 1 to 3 of 3
    634
    Default R8 Door latch spring
    Hi again
    i just want to know how necessary is the tension spring that is used on R8/10 door latches?
    each latch I have pulled off either has the spring missing or broken.
    there seemed to be no issue operating the doors, so wonder how necessary the spring is?
    cheers
    Angelo
    Attachment 85736Attachment 85737
    Simon's Avatar
    6,161
    The spring is in place to limit the button rattling in the stainless handle, depending on the various tolerances and assembly method. This was the reason for the plastic "washer" in the later cast door handles. The earlier type stainless handles don't use a plastic "washer".
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    634
    Thanks Simon, that makes sense. So I take it that the SS handles were the early R8 and cast were the later (improved) version.
    so if I leave it off, the worst that can happen is an annoying rattle.
    cheers
    Angelo
