Renault Clio II - Engine missing and fuel filter location
Results 1 to 13 of 13
  • 1 Post By c.lees
Thread: Renault Clio II - Engine missing and fuel filter location
    Member jb007's Avatar
    Aug 2015
    Altona Meadows, Victoria
    96
    Icon5 Renault Clio II - Engine missing and fuel filter location
    Hi all. No nobody has stolen the engine, rather it has a random miss at idle and is more noticeable at light throttle settings. This started this morning out of the blue.
    Last year I had a similar problem, not the same though in feel. This was two pencil coils. I replaced all four plus sparkplugs, problem solved.
    At my local Repco outlet, one of the guys there suggested a new fuel filter as I have only done 99000Kms and to my knowledge no fuel filter has been changed (nor timing belt!). I have also put some injector cleaner in fuel.
    Where is the fuel filter located?
    What else is a common fault that could cause this?
    Where can I get a workshop manual for this car?
    Cheers Jim
    2004 MY Clio Privilege 1.6L Manual 99,000Kms
    2017 Renault Clio Expression 1.2l
    2002 Peugeot 206 XT 1.6 Manual
    http://www.jims-blog.com
    Oct 2012
    600
    The Haynes workshop manual can be obtained from ebay, mine was shipped from the UK, cheaper then here. I can look up the location of the fuel filter when I get home.
    jb007 likes this.
    Aug 2015
    96
    Thank you. I'll look on ebay... could not see filter crawling under car... need ramps but I've just moved house and the garage is in a right mess.
    Jim
    1000+ Posts driven's Avatar
    Apr 2005
    1,424
    Free manual, just download, any vehicle
    RENAULT CLIO MANUAL Pdf Download.
    8,675
    I don't know much about Renaults, but in most modern cars there is one immersed in the fuel tank.
    Dec 2010
    Blackburn Victoria
    472
    Clio fuel filter is located near the leading edge of the fuel tank.
    Sort of under the right rear passenger.
    Access from under the car with quick disconnect fittings on plastic fuel lines.
    Having said that, logic would dictate that at low throttle, less fuel is required, but under heavier
    throttle, more fuel needs to flow. A restricted fuel filter would inhibit the higher flow rate.
    I would revisit spark plugs and ignition system, fuel grade, "sticky" fuel pump - etc.
    Oct 2012
    600
    I can't find anything in my manual about a fuel filter, my manual is only for the k series petrol engines and the diesel.
    Aug 2015
    96
    Thanks all, I'll tackle this problem tomorrow on my RDO. I feel it's ignition related, I have a couple of spare coil on plugs somewhere in the garage... guess I'll be taking the ever reliable Mini to work today.
    The exhaust has a random miss to it.
    Driven... I can only find owners manuals on that link, am I missing something?
    Aug 2015
    96
    Ok, found my old coils, changed it onto all 4 cylinders... no difference still has semi rhythmic miss. Looked at plugs (BOSCH Platinium) they all look good and slightly wet (as engine is cold) except for the one nearest to drivers side where it looks very dry.
    Maybe injector(s) as these are the original. Car is idling low, but misses still when revving it.
    If injectors, where is a place that I can get some of the shelf today besides renault?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Do you have a diagnostic tool to see if there are any codes.
    It may take some of the guess work out of working out what the problem is.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Aug 2015
    96
    Fixed! Pulled the plugs again and noticed the one on nearest the clutch end was very wet. I bought these Bosch Platinum plugs last year when I changed the ignition coils.
    Sometimes it the simplest of things. Not impressed the spark plug crapped itself though. There is no signs of arcing down the insulator, so it must be on the nose of the insulator. Go figure!
    Thanks all for your help.
    Jim
    10,754
    Quote Originally Posted by jb007 View Post
    Fixed! Pulled the plugs again and noticed the one on nearest the clutch end was very wet. I bought these Bosch Platinum plugs last year when I changed the ignition coils. Sometimes it the simplest of things. Not impressed the spark plug crapped itself though. There is no signs of arcing down the insulator, so it must be on the nose of the insulator. Go figure! Thanks all for your help. Jim
    I couldn't offer help but was following with interest! I was hoping to find you'd fixed it today - plugs eh!! Can't blame Renault for that, not that you were. Really good to hear that it is fixed.
    When Peugeot nearly beat Audi at Le Mans in maybe 2008, they were faster, won the whole endurance series but lost Le Mans due to a Bosch battery that failed in their lead car if I recall.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Aug 2015
    96
    Yep, just one plug! In all the years I've been driving (42) I can't recall ever having a plug go on me. I wanted to replace them with NGK's but where I was was out of them, and I was trying to complete my house removal. Cars going sweetly, even idles properly from cold. Maybe the plug(s) were failing slowly and I din't notice?
    Stay tuned for my timing belt change thread!
    Jim
