R12 Exhaust Stud
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By Stuey
  • 1 Post By Peter J Kent
Thread: R12 Exhaust Stud
    Brisbane/Australia
    2,067
    Default R12 Exhaust Stud
    Guys,
    Do any of you know the size of the exhaust studs on the R12 manifold.
    (Part number 7700521051 on the attachment and it's a R12TS manifold if that makes any difference).
    I have to replace some but the ones on there are too rusty to measure accurately.
    I'm guessing they're about a M6.
    I've got to separate the manifold from the exhaust pipe and I'm pretty sure one or all three will snap when I try to undo them. (Even after applying copious amounts of penetrating oil and the blowtorch).
    I'm sure if I buy some replacement studs none will break and if I don't buy them all will break.
    Ren
    10,815
    Sorry, not sure whether they are the same as R8/10. Did they come with brass nuts like the R8?
    Let it soak another week?
    Good luck as usual!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    19,103
    Every French car I'm worked on has M8 studs securing the manifold to the head.
    The studs are often available in "universal" styles from speed shops or generic parts wholesalers, because there is a crossover to Japanese vehicles using the same thread studs.
    I generally use Stainless steel nuts, instead of brass because they still have anti seize properties, are readily available, are cheap as chips and are lot less likely to strip than brass nuts.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,071
    Those studs that hold the exhaust to the manifold are 8mm Diameter 1.25mm pitch and 38mm long.
    I would be using a impact socket (6 sided) instead of a 12 point socket to remove the nuts so that you do not rip the corners off the nuts and make it harder to get apart.
    On re-assembly I would be using something like Kopr kote on the threads.
    All the Renaults I have seen have used steel nuts which get affected by the heat, but you could use stainless nuts like Rob suggested which will not be affected by heat as much.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    10,815
    Interesting - both of mine have brass nuts. They are tightened with extreme care! And Kopr-Coat....
    Renault 4CV 1951
    Renault R8 1965
    8,914
    Well, you got your answer about the size, no need for me to reinforce the above.
    About nuts, now.
    Brass nuts are fine, actually very good, because they will never get welded to the studs no matter what. Rob may be right with SS, but then again, exhaust manifolds don't need to be tightened to high heaven. Brass nuts never gave me any trouble ever. The grease used is just copper (or nickel, or silver if your pockets don't care) to prevent welding of said nuts. Brass nuts of course don't need any of that stuff. That's the whole point of using them.
    Better than brass nuts however, there is another option. Again you have to have deep pockets. Go to your local Honda dealer and buy some of their OEM exhaust nuts. They are copper plated and have a slit in the dome to prevent coming undone. Again, I have never worked on a Honda and found problems with taking exhaust manifolds off. The copper is corroded in time, but they still come off clean and you can replace then. They also have copper coated studs in sizes you can use on a Renault.
    Recently, I have seen in WA some shops have generic copper coated exhaust studs, but am not sure of the quality.
    ACHTUNG ALLES LOOKENPEEPERS
    Brisbane/Australia
    2,067
    Thanks guys.
    The nuts that are on there are steel. The manifold is off the car so I could always grind the nuts off if necessary or use a nut splitter.
    I don't know if these are the original nuts from factory or a previous owner fitted them.
    Personally, I always use brass nuts on the exhaust studs and a smear of copper grease.
    I haven't used stainless steel. They'd be stronger than brass but as mentioned earlier, strenght isn't a huge issue on the exhaust pipe.
    But I have to get these nuts off first and then I can replace the nuts and studs.
    There are plenty of generic exhaust studs for sale on fleabay but of course one needs to know what size to buy first.
    I don't need to go too fancy. New steel studs and brass nuts will last until I die, what happens afters that doesn't trouble me.
    Ren
    10,815
    The good thing is that you aren't going to be stuck with studs broken but still in the head if the manifold is off. Interesting about the Honda nuts!
    Renault 4CV 1951
    Renault R8 1965
    4,379
    The OP is talking of the bottom three studs at the base of the manifold though. This is eqivalent to the clamp arrangement for the muffler on an R8/10. I normally just undo the nuts and reuse those and the studs on my white R10 which uses a similar R12 manifold. Haven't had an issue in nearly 20 yrs but they can suffer from rust issues.
    Last edited by renault8&10; 23rd April 2016 at 04:32 PM. Reason: Autocorrect, clamp to clump!
    KB
    10,815
    The OP is talking of the bottom three studs at the base of the manifold though. This is eqivalent to the clump arrangement for the muffler on an R8/10. I normally just undo the nuts and reuse those and the studs on my white R10 which uses a similar R12 manifold. Haven't had an issue in nearly 20 yrs but they can suffer from rust issues.
    Ah, I missed the point somewhat. Thanks Kevin.
    Renault 4CV 1951
    Renault R8 1965
    Newcastle
    2,624
    Default Nuts to you too :)
    Hi
    Seeing as this has developed into a 'nutty' discussion with some useful information I will put up my based on my general experience.
    Brass nuts are just as strong as steel nuts. BUT they can suffer from thread damage and stripping easily if the stud thread is burred or damaged. I always use an anti sieze grease on any exhaust parts. Just good practice.
    SS nuts can be a bit soft and not as strong as normal steel nuts. Depends on the grade. Same for studs.
    Jaahn
    8,914
    I realised that. They are the same size, M8, and everything I said applies.
    I just remembered, you can buy the copper plated nuts with the side split dome from some of the WA better car part shops. Again, their origin is unknown, so you kinda are on your own. I have used them and so far so good.
    6,311
    Brass nuts are OK up in Brisbane, but they will come off if you use them in Tasmania, especially in winter.
    59 Floride likes this.
    2003 PEUGEOT 206 GTi
    8,914
    Not sure about that. They might crack and split if the material is crap and it gets too cold, but I don't think Tasmania has that kind of temperatures.
    Sweden, maybe.
    Dec 2004
    749
    maybe if attached to a brass monkey
    jaahn likes this.
    LIFES TOO SHORT TO DRIVE BORING CARS!
