Targa Tassie - wanted R8G dipstick
Results 1 to 11 of 11
    Canberra ACT
    721
    Default Targa Tassie - wanted R8G dipstick
    Hi all
    Had a great time in my A110 doing Targa Tassie with the Renault Targa Team (3 A110s, a R5T2, Megane 225 and a Porsche). Plenty of photos are on Facebook.com/renaulttargateam
    At the completion of the awesome Arrowsmith stage on Thursday 14 April, I stopped at our service crew for a splash of fuel and oil but forgot to replace the dipstick which was nowhere to be found. We were too late for the next stage anyway ( the zero or sweep car had gone past) and of course there was oil around the engine and over the coil which meant the car was starting to misfire. We improvised by duct taping a philips head screw driver in the dipstick hole which plugged the oil hole (it lasted the rest of the week) and continued on to Strahan getting a preview of the next morning's stage to Queenstown.
    Using a coat hanger wire, it looks like the length of the dipstick from the hole to the bottom of the sump is 47.5cm. Can someone confirm and also advise distance of minimum and maximum notches. Better still, if someone has a spare dipstick for an R8G motor, I would appreciate it. A gentleman at our stop did lend me a dipstick from his Subaru which established I still had ample oil before we proceeded to Strahan. A visit to our local wreckers might be the order of the day for a similar dipstick if none are available here.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Hi Bazzamac
    Is this one close to what you are looking for
    Renault Moteur "B" Billancourt 800S61 Jauge D'Huile Moteur | eBay
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Dec 2010
    Blackburn Victoria
    502
    Hi Barry,
    Will be able to measure an original 8G dipstick for you tomorrow (Thursday ) afternoon.
    Cheers, Steve.
    Simon's Avatar
    6,203
    Hi Bazzamac
    That looks like one for an R4.
    I've attached a few pics with measurements. From the top of the "cap" to the tip of the stick is is 437.5mm, width 5.5mm. From top of "cap" to top of handle is 69mm.
    Note that the width of the stick is identical to that used on the early 15/17 auto trans dipstick (pre plastic paddle type). I'd guess if you can find one of those, you should be able to make a fairly good facsimile of the original dipstick. Also note the chamfer on the low mark of the dipstick, so that the stick doesn't snag on the upper tube when it is being pulled out.
    Attached Thumbnails Attached Thumbnails Targa Tassie - wanted R8G dipstick-dsc07985.jpg   Targa Tassie - wanted R8G dipstick-dsc07982.jpg   Targa Tassie - wanted R8G dipstick-dsc07986.jpg   Targa Tassie - wanted R8G dipstick-dsc07988.jpg   Targa Tassie - wanted R8G dipstick-dsc07989.jpg   Targa Tassie - wanted R8G dipstick-dsc07992.jpg
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    wielder of the sword Australdi's Avatar
    spinsterhood
    3,410
    If all else fails...one of us locals might go for a recovery mission drive
    Aus
    ".....the good health of a pond is held in a delicate balance. A pond's condition
    deteriorates when the bottom environment cannot support animal life.
    The bottom is the area that runs out of oxygen first, it is where the most oxygen is used........"
    '84 fuego GTX
    '87 fuego GTX
    '85 fuego GTX
    ....beginning to look a bit frightning isn't it.
    11,186
    Brilliant Simon! I agree the one advertised doesn't seem right: I think that dipstick for sale is from a Ventoux motor not a Sierra motor: I quote from the advertisement "845 cc ŗ 3 paliers".
    It looks like a Sierra dipstick in the advertisement, but I guess they might have added an antisplash tube like an R10 engine and used a similar pattern dipstick for the later examples. Oddly, your dipstick looks like the one for our 1964, early R1130 motor but our R10 block Sierra engine has a dipstick of the same style as the one in the advertisement.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Canberra ACT
    721
    thanks Simon and everyone else for your advice. Measurements will be handy should I need to make a copy. I have at least 3 Fuego dipsticks but they are far too short. The one shown in the ad referred by Col looks like one from the R8Major motor which was originally in the car and it is too short.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Hi Bazzamac
    The description said R6 and I was not sure if it would fit or could be adapted.
    It was the only one that I could find.
    Regards Col
    1973 Alpine A110
    Dec 2010
    Blackburn Victoria
    502
    Hi Barry,
    8G dipstick dimensions measured from bottom of felt sealing washer.
    75mm to top of handle.
    387mm to top of notch - oil max
    403mm to bottom of notch - oil min
    430mm to tip of dipstick - your oil is way too low and you are about to become a very sad Alpine owner with a stuffed engine...
    Hope this helps,
    Steve.
    Simon's Avatar
    6,203
    From the dimensions supplied, it sounds like the dipsticks are the same. Just a thought from me though, I wonder if an A110 1300G/S dipstick is different from the 8G, as I'm unsure of the oil cooler/line setup. In the 8G, it allocates 0.7 litres to the cooler and lines in addition to the 2.5 litres in the sump (obviously if a Big Sump is fitted this sump capacity will be different!). So also check your cooler and line capacity (especially if customised) to make sure any markings on the dipstick are accurate.
    1963 Renault R4 Van
    1964 Renault R4
    Canberra ACT
    721
    Thanks Steve and Simon
    My car has an oil cooler. For Targa, I replaced the alloy sump with a standard sump just in case the more expensive one might be damaged. Agree it is essential for oil markings to be accurate, hence my request for dimensions should I need to make up a dipstick.
