Scrap Virage
Results 1 to 24 of 24
Like Tree4Likes
  • 1 Post By Simon
  • 1 Post By schlitzaugen
  • 2 Post By Stuey
Thread: Scrap Virage
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,395
    Default Scrap Virage.. (Ed, actually late Series 2, 12)
    So what did you do today? I went and rescued.. no mostly just extended a Virage's live by perhaps a week.
    Getting her home and throwing a lot of water at her.. Well, she is complete.
    I'm going to go through it and save the bits I want, but best start thicking if there is anything your Virgage is after.
    It's white. most of the panels are rubbish and I'll be keepnig the good ones. It has that 80's style'd dash that looks more dated then the early stuff, I won't be keeping that, but wierd things like the tool kit pouch, virage hub caps, weather strips etc, we'll I'd be happy for them to be complete someone's "resto"
    Idea is is to rip everything off it and call the wreckers to come take the shell away, The race is on because my partner has given me till next sunday
    The one panel I was after (right hand side guard) has rust in the top! How the heck did water collect there and not at the bottom? :S oh well. The bonnet appears good too. and althought my car is green white, this white bonnet is closer then the blue. The boot lid is total junk in case that was going to be your next question.
    Some horrible picks below.
    Oh and what's with these late wheels. Did they really just cut the centres out to fit hub caps? And yes, that spare tyre in the boot is brand new
    Attached Thumbnails Attached Thumbnails Scrap Virage-imgp4058.jpg   Scrap Virage-imgp4057.jpg   Scrap Virage-imgp4055.jpg   Scrap Virage-imgp4054.jpg   Scrap Virage-imgp4053.jpg   Scrap Virage-imgp4052.jpg
    Scrap Virage-imgp4051.jpg   Scrap Virage-imgp4050.jpg   Scrap Virage-imgp4049.jpg   Scrap Virage-imgp4048.jpg   Scrap Virage-imgp4047.jpg   Scrap Virage-imgp4046.jpg
    Scrap Virage-imgp4045.jpg   Scrap Virage-imgp4044.jpg   Scrap Virage-imgp4043.jpg   Scrap Virage-imgp4042.jpg   Scrap Virage-imgp4041.jpg   Scrap Virage-imgp4040.jpg
    Scrap Virage-imgp4038.jpg   Scrap Virage-imgp4036.jpg   Scrap Virage-imgp4035.jpg   Scrap Virage-imgp4034.jpg   Scrap Virage-imgp4033.jpg   Scrap Virage-imgp4026.jpg
    Scrap Virage-imgp4025.jpg   Scrap Virage-imgp4024.jpg   Scrap Virage-imgp4022.jpg   Scrap Virage-imgp4021.jpg   Scrap Virage-imgp4019.jpg
    Simon's Avatar
    6,172
    That particular car is actually a 12 1.4 ( and a Series 2 1.4 at that), rather than a Virage (which has four headlights), although given its number it is one of the final 12 1.4s assembled.
    The guard rusts at the top, as it has a modified drain tube for the plenum, which holds mud behind it rather than the earlier long drain tube, which holds the mud in the bottom portion of the panel (the underseal cracks, letting the moisture in, the tube then holds the mud and moisture in place).
    An original tool kit pouch will also be worth at least one concours point to someone!
    Also, don't use that locking fuel cap on your car, it is non-vented, your early model 12 requires a vented fuel cap. Those holey wheels also make them easier for tyre places to balance them as well!
    Happy scrapping!
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Aug 2002
    3,395
    There is not much you don't know about these things is there That makes sense, the rust that is after looking at my earlier 12.
    Thank you for the heads up the petrol cap. And good to know about those wheels!
    10,783
    You know, those late model R12 cars were well made with good materials, when you look at them now. We had both 1.4 R12 and Virage models, and they looked the same internally 25 years ago.
    The later wheels make much more sense, as Simon pointed out. As he said, happy scrapping.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Aug 2002
    3,395
    Hmmmm 847 Power
    Also that master cylinder and booster... it's different to the one in my 71 R12, is this the better one I was looking under 15's and 17's for?
    Aug 2002
    3,395
    I was quite surprised once I gave it a vacuum I mean there are a few things that have been sun tanned.. but the lining on the roof is still intact! :S That never happens.
    Simon's Avatar
    6,172
ID:	82616Click image for larger version.
    Hmmmm 847 Power
    That is the latest type master cylinder (with integrated pressure drop indicator), also a dual curcuit type. Whereas the one on your early 12 is (if it is still original) a single circuit master cylinder and lines. The 12 master cylinder has a 19mm bore the 15/17 cylinder has a 20.6mm bore.
    Melc likes this.
    1963 Renault R4 Van
    1964 Renault R4
    Aug 2002
    3,395
    Yes the is the one in my 12;
    Right. best hang onto those lines as well then.
    10,783
    Well, well. It seems they stuck with those particular diameters model after model after model. Quite under-rated, late R12s.
    Renault 4CV 1951
    Renault R8 1965
    8,899
    Yeah, I was going to suggest you hang on to the brake bits including the lines themselves and the fittings.
    Window seals if in good nick are worth keeping too (or swapping if yours are shite).
    If I were closer I would ask for the front seats.
    The front end plastics are remarkably well preserved as well. Not only that everything is there, but they seem in very good shape.
    I think you've got quite a few good bits hanging on that girl.
    JohnW likes this.
    ACHTUNG ALLES LOOKENPEEPERS
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,663
    Bowie,
    Would you take a picture of the windscreen wiper motor please. and post it. I presume this is a lever actuator for the wipers ???
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Aug 2002
    3,395
    Will do ray.
    Yes I suppose they are lever driven, I wasn't able to lift either of them far off the windshield when I was cleaning it earlier. This is what you mean by lever driven?
    Aug 2002
    3,395
    And sorry Schlitzaugen, Those front seats are for me. Both mind are saaaaaaaaaged. I didn't realise the covers look like they upzip off the body. I might be able to dress this good foam in my green leather! HUZAH!
    Oh and these things have retractable seatbelts. Luxury!
    4,377
    He means the arms that actuate it - probably behind the dash or perhaps in the scuttle area.
    The pics may have to be taken as you strip it
    KB
    Aug 2002
    3,395
    Ah yes yes. I thought the exterior arm itself would give away if that was the model he was chasing, as they are different to my early 12.
    8,899
    They're all lever actuated, how else? the motor is under the dash, on the Virage might be a bit better hidden, but still the same jobbie.
    Fellow Frogger! Melc's Avatar
    Apr 2003
    239
    Just look under the passenger dash area. Voile!! Wiper motor. I have this exact car as a one owner, if I were not in Bris, it would be beer and spanners at dawn....
    4's 16's and Caravelle
    8,899
    So, shall I bring my duelling stubby holder?
    Aug 2002
    3,395
    Bowie,
    Ray
    This thing?
    Perth, WA
    1,663
    Hi Bowie,
    When you get to this, I would like you to earmark for me please, with the arm that rotates on the drive spindle.
    PM me the price please.
    Thanks,
    Ray
    Ray geckoeng
    6,283
    I once reached up under the dash of my R12 while the wipers were on. That's how I found they were lever driven. Almost scissor chopped my fingers off, between the pivot of the levers. Rather sore, that was...
    jaahn and chodaboy like this.
    2003 PEUGEOT 206 GTi
    Aug 2002
    3,395
    Hi Bowie,
    Thanks,
    Ray
    Will do Ray.
    8,899
    Why would you want that piece of a dorongo? Don't mean to take business away from our dear bowie, but those motors are horribly inefficient, unreliable and weak. You can use almost any motor, just need to re-drill the holes in the mounting bracket. From foggy memory an E30 BMW motor fits two of the hole, so you only need to re-drill one, is slender and a lot more powerful. My plan is when mine carks it, I am going to use a Prius motor. Those things can swing a wiper the size of South America.
    6,283
    A Prius motor would work, but it's fitting the batteries in that will be a challenge. But boy, those wipers will WIPE!
    Seriously though, I can't understand why you'd put that much effort in. There are so many more fruitful things to spend your time on. It's not like wiper motors are a common failure point. Keep the spindles and pivots lubricated and Bob's your uncle.
