Carburettor repair recommendation?
Results 1 to 22 of 22
Like Tree2Likes
  • 1 Post By Balki
  • 1 Post By geckoeng
Thread: Carburettor repair recommendation?
    Apr 2011
    strathfield NSW
    34
    Default Carburettor repair recommendation?
    Can anyone point me towards someone who can refurbish my weber carby - my car is a 1969 Renault 16ts. I know and have been to CSC in Burwood but 400 bucks is a bit stiff.
    Dec 2004
    748
    ring Recarb in Taree
    Cheers Peter
    LIFES TOO SHORT TO DRIVE BORING CARS!
    Dec 2004
    748
    Try Recarb in Taree
    Cheers Peter
    Apr 2011
    strathfield NSW
    34
    Thanks Peter - seems like recarb has relocated to somewhere north of Brisbane. I should have said I need someone close to Sydney.
    Apr 2011
    strathfield NSW
    34
    Peter - I think you meant "Procarb"
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    623
    procarb in tassie does a great job, cost $380
    addo likes this.
    Nov 2005
    Geraldton
    1,567
    Try googling Pierce Manifolds. A US based firm I've dealt with. I got a new conversion for a triton ute cheaper than a second hand unit or a recondition.
    In the Shed(s):
    In the Past:
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,089
    Yes Recarb in QLD. Very helpful.
    https://www.recarb.com.au/
    We are located on the sunshine coast of Queensland at:
    4 Waterview St, Warana, Qld 4575
    Phone Number : (07) 5493 3788
    Either get a full rebuild kit and do it yourself or
    get a mate that has done some. No beers while your doing it. LOL
    Just do it very carefully and note which jet, etc. came from...
    Note: if the butterfly shaft is worn then you should take it or send to someone. It would be sucking air.
    also the gasket surfaces should be flat. Check these.
    Good luck
    Don't remind me!
    16,609
    If one had the tools for upsetting new lead balls, and a stock of them, it would be a simple matter of DIY plus kit, plus time.
    In respect of Sydney wages for anything, I don't see $400 as excessive to go through a carb, it's a bit steep if the thing is just getting a solvent bath and gasket kit but for a full clean including the transfer passages it is not bad.
    8,859
    Can‘t you just use the lead balls you can buy in fishing supplies‘ shops?
    ACHTUNG ALLES LOOKENPEEPERS
    Don't remind me!
    16,609
    Maybe! The rebuild guides infer the setting tool is slightly concave on its striking face, but maybe there are two tools used and the finishing one is flatter.
    Nov 2005
    Geraldton
    1,567
    Again, I think you can buy a new carb cheaper than you can get one reconditioned in Oz.
    In the Shed(s):
    In the Past:
    8,859
    A new carb for a 1969 R16? That is something.
    I know you can buy the DGV 32/36 new, but it‘s going to be well north of 400AUD. Better carb though, and if I had long term plans, I would go for it.
    Apr 2011
    strathfield NSW
    34
    Thank you all - very helpful information and after having done some research on what some you said I realise I discovered that exfrogger and schlitzaugen are absolutely correct - a new DIR and DGV are $400 and $467 brand new from webber performance in Melbourne. I will go the cheap route first viz get a kit and have a go with the current carb and if that doesn't work get a DGV. Thanks again.
    Nov 2005
    Geraldton
    1,567
    Or $199 U.S., new
    In the Shed(s):
    In the Past:
    19,041
    BYO jetting ? Or to order ?
    Nov 2005
    Geraldton
    1,567
    Mine came jetted but it needs some re-jetting. The dvd gives pretty explicit instructions on what to do to get it in the zone.
    Mine was a conversion. If you have an old carb with the right jets it should be pretty straight forward.
    In the Shed(s):
    In the Past:
    Boonah Qld
    2,521
    Or $199 U.S., new
    Plus high postal costs?
    Nov 2005
    Geraldton
    1,567
    Actually not outrageous.
    In the Shed(s):
    In the Past:
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,643
    Actually, I read on the forum all the time, guys complaining about postal charges from Europe and the States, But have you tried to post from Oz to Europe or USA ???
    Them You see what costs are, and the couriers in Oz also hop on the band wagon.
    Think again about post or courier costs, they are not really that bad.
    addo likes this.
    Ray geckoeng
    Think Old, But Run Modern !!
    Mar 2013
    olinda victoria australia
    695
    Default carburettor
    A mate used Weber performance in Melbourne for his racing celica
    They asked what he was using it for, size of motor, state of tune, powerband etc etc
    Came down jetted and ready to go. Bolted it on , connected everything. Started first go and idled perfectly
    It'll probably cost more from then than on fleabay, but you might end up not scratching around for quite so long
    Also supports local bloke
    Andrew
    Quote Originally Posted by zaccy View Post
    8,859
    That doesn't sound like a bad deal. You can also get your hands on a very cheap DGV if you're lucky and raid your local pick a part yard. How's 20$? Trick is to find a Cortina or some other stuff like that that came with it from factory before some other scavenger gets it.
