welsh plugs
Results 1 to 25 of 31
Like Tree6Likes
Thread: welsh plugs
    Jul 2003
    bundaberg
    338
    Default welsh plugs
    My engine rebuilder is having trouble finding a 63 mm welsh plug for my 807 engine. Any clues as to a supplier?
    Geedee
    19,041
    Jul 2003
    bundaberg
    338
    As such a size does not seem to exist what have others used when rebuilding their 807 engines?
    19,041
    63 mm = 2.4803 inches
    So I'd suggest a 2.5 inch (63.5 mm) plug is probably usable. Even if it need a little easing on the belt linisher.
    I can't help wondering how accurate the quoted measurement is ?
    Jul 2003
    bundaberg
    338
    Will check with my motor man when I get over a rotten cold I have at present.
    8,675
    In Europe plumbing fittings and much else are still made in inches and fractions thereof - but they express things in rounded mm. If that is true for welch plugs, you are looking for a 2 1/2" one. Measure the casting.
    19,041
    Quote Originally Posted by geedee View Post
    I've got a cold too. Suggest you dose up on Codral Colds, flu & cough tabs. It's the first product I've found that gives effective symptomatic relief.
    If you run out of "night" tabs, you can buy them separately.
    My symptoms seem to hit me about 2:00 pm And peak at 10:00 pm.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Just been out in the shed and looked at a 807 head that I have out there that has had a new welsh plug fitted. It has 2 1/2" hand written on it.
    2 1/2" is 63.5mm as I id not fit this welsh plug I'm not sure how hard it was to push in.
    So like Seasink & Robmac says a 2 1/2 inch one will do.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Simon's Avatar
    6,161
    I'm guessing this is the plug at the timing gear end of the head? If so, a couple of part numbers to try, 77 00 559 223, superseded by 77 03 075 046
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    10,754
    I've got a cold too. Suggest you dose up on Codral Colds, flu & cough tabs. It's the first product I've found that gives effective symptomatic relief. If you run out of "night" tabs, you can buy them separately. My symptoms seem to hit me about 2:00 pm And peak at 10:00 pm.
    Not exactly a Renault item, but those Codral tablets are a standard, essential item in my O/S travelling kit - they are the way to avoid EVER flying with blocked ears if you get that cold when travelling. NEVER fly with blocked ears. NEVER.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    19,041
    Never fly with a blocked Eustachian tube to be precise.
    If blocked, you risk rupturing an ear drum if ambient pressure changes. Because the pressures on either side of the ear drum are unable to balance.
    10,754
    Exactly. A Renault friend of mine had to buy a cheap car and drive home to Perth from northern NSW a few years back, with two ruptured ear drums from the flight up. You didn't mention the pain - apparently is it extreme, to put it mildly. I can barely imagine.
    Renault 4CV 1951
    Renault R8 1965
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,953
    The origins of a plug that did NOT originate in Wales are found here:
    http://www.britishcarweek.org/welch_plug.html
    Sunroof, cjl and Gamma like this.
    19,041
    Care to inform us about Dr Young's b**** plugs while you are espousing the history of plugs ?
    Melbourne, Aus.
    17,953
    Not sure where you are coming from there, Rob, I'm only an expert on stop butts, not butt plugs.....
    8,859
    Not sure where I found it (it was some time ago), but metric welch plugs do exist in all sizes. They're all, of course, very approximative. I remember measuring and they are easy 0.5mm or more larger. My suspicion is they're just imperial sizes rebadged. Use brass and it'll go in easy enough. Just don't bash in the middle. Have a drift almost the same diameter as the plug and when it's in, to seat it properly bash it gently and squarely with a drift the diameter of the lip, so the lip expands against the circumference.
    ACHTUNG ALLES LOOKENPEEPERS
    10,754
    I'm pleased to say I've never had the need to even touch one of these horrible devices. At least they seem horrible to me.
    Renault 4CV 1951
    Renault R8 1965
    1000+ Posts driven's Avatar
    Apr 2005
    1,424
    The best "Drifts" for Welsh plugs I have found are the ever reliable socket set
    gsmack likes this.
    8,675
    I haven't changed one in years, but when I rebuilt engines a couple of taps with a ball pein hammer did the trick to fit them tight in against a touch of jointing compound. Brass ones needed a soft touch.
    8,859
    That's true, but I doubt most of us would have a 63mm socket in our collection.
    19,041
    Quote Originally Posted by Kim Luck View Post
    So what is wrong aren't you interested in expanding your knowledge ? Not to mention expanding something else.
    The added advantage, if so fitted, is nobody could claim you are speaking through your proverbial, because it would be well and truly and sealed.
    8,859
    Geez, Rob!
    Apr 2005
    1,424
    True, for large sizes, down to the local plumbing shop.
    Piece of 50mm NB Gal pipe has an od of 60 mm and 40mm NB has an od of 48mm
    Nov 2005
    Geraldton
    1,567
    Same as the original poster. I need to source a 63mm and all I could get my hands on was a 2 1/5" or 63.5mm.
    Geedee how did you solve the issue?
    P
    In the Shed(s):
    In the Past:
    Jul 2003
    bundaberg
    338
    Will have to check with the engine rebuilder as it was some time ago and the memory needs an upgrade.
