Help with power for a Dash Cam
    Jan 2016
    Melbourne, Victoria
    3
    Default Help with power for a Dash Cam
    Hello all,
    I have installed a Blackvue DR650 2ch dash cam and a Power Magic Pro in my sons Renault Koleos and am having issues with power.
    I have taken permanent power from the rear lamp fuse (Yellow Wire).
    I attempted to take Acc power from the rear cigarette socket but when i do and the car is off the camera powers down.
    The camera is meant to enter parking mode but currently does not.
    Hoping someone could please assist me.
    Thanks Shane
    Fellow Frogger! G4ME's Avatar
    Feb 2003
    813
    Did you use the Usb cable supplied and cut the cigarette lighter adapter off to hard wire it? If so the cigarette lighter actually changes the power. Have a look at the amp specs for the unit and buy an adapter from eBay and it will give the right output for the camera. I made the same mistake and this fixed all my problems.
    Paul
    There is a law against doing more than 100kmh...there's no law on how fast you get to 100kmh!!!
    Jan 2016
    Melbourne, Victoria
    3
    Feb 2003
    813
    Quote Originally Posted by DaCrazyOne View Post
    Hi Shane,
    I bought one of these
    Waterproof DC DC 12V TO 5V 3A Mini USB Converter Adapter CAR LED Display | eBay
    USB cables run at around 5v and 3amps. Check the specs of your unit but once I used this adapter it solved most of my problems I'd caused by cutting off the cigarette lighter adapter. I am assuming you configured all the setting either through the console or on a PC first??
    Cheers...Paul
    lost
    11,055
    Icon6
    G'day,
    what is the video image like ?
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
