Renault Scenic 2003 Aicon
Results 1 to 9 of 9
Thread: Renault Scenic 2003 Aicon
    Feb 2014
    Rochester Victoria Australia
    37
    Default Renault Scenic 2003 Aicon
    Hi i have a 2003 Renault scenic and for a number of years have had a problem with the air con which is it works most of the time (perfect) then other times it wont turn on ie: the clutch wont engage.
    Also sometimes when it is not working and driving along going over a bump on the road can make it come on.
    So thinking it is a short in the wiring somewhere . But where, has any one had this problem and found a short in the wiring. as not getting power to the clutch.
    Fan always works on all speeds it has climate control , Yes swapped it with a working one.
    Please note over the years lots of things have been looked at and even replaced with no change. THE fan resistor,pressure switch,climate control panel have all been changed, gas is fully charged and has never leaked. (its been checked)
    When it works its perfect icy cold.
    Im looking for a short in the wiring Any one had a problem like this .
    thx
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Your problem will not be a short, it will be a bad connection somewhere.
    With these sorts of problems (intermittent) can be hard to find sometimes. At the time when you are looking for the problem the fault needs to be there.
    The fault could be just a bad connection in a plug somewhere or it may even be in the air con controller.
    I know I'm not much help, maybe you need to take it to a good auto sparkie.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Feb 2014
    37
    yes i used wrong wording not a short as would blow fuses etc. a bad connection is better.
    Have checked every plug can get to even with top dash off.
    As for a good sparky well you can guess what they want give me $500 and we should be able to fix it after we replace every thing.
    but carnt tell you what the problem is ,cos they dont know. Bit like a Renault dealer lol
    The air con controller has been swapped over from another car.as i have 4 spear scenics to get parts from. so not that.
    11,295
    Could there be a bad connection inside the clutch unit itself? With four (greedy ) spare Scenics you might have one.
    Good luck. I hate intermittents.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Feb 2014
    37
    .yes could be, im starting to think prob is somewhere under or around the fuse box in the engine bay.
    yes to many Renaults 2x scenic RX4, 3x scenic , 2x scenic II , 1 x megane II, 2x koleos
    all for sale except koleos
    scenics were my hobby but kinda over them going to play with the koleoss now
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Good idea John and could be swapped over fairly easily.
    Regards Col
    1973 Alpine A110
    Don't remind me!
    16,609
    Could you wire in a temporary LED telltale in parallel with the clutch feed? I'm presuming it's a variable displacement compressor so mostly stays on when the AC is selected.
    Dec 2004
    VICTORIA
    83
    Hi: You can usually hear the air con clutch engage when put your head under the bonnet. So maybe get a friend to turn your air con off and on as you listen under the bonnet. Or turn it on and connect and disconnect it at the connector. With the car stationary no other movement should occur to wiring. I'd suspect that it is the air con clutch itself - on its way out. If it works sometimes and not others on this test I'd be looking at swapping the clutch/compressor.
    Feb 2014
    37
    don't think its the clutch as when it works you can turn it on and off a dozen times, this car has had this problem for 5 years,so the clutch would have given up by now. With the car stationary can hear the clutch kick in when it works.
    but yes it could be the clutch with a mind of its own, just a tricky thing to get at.
