R12 Timing
Results 1 to 19 of 19
Like Tree4Likes
Thread: R12 Timing
    Brisbane/Australia
    2,199
    Default R12 Timing
    Guys.
    There are no timing marks on my R12 motor (type 842-01 1251cc).
    There's a dimple on the crank-pulley but nothing on the timing chain cover.
    There don't appear to be any spotwelds on the cover so it's not as if it's been broken off, it looks like they were never there.
    This is my 5th R12 and I've never seen one without a timing mark before.
    So how does one set the timing on these, just by the dwell angle, or do it by ear, or adjust the timing until it sounds 'sweet'?
    I have 5 or 6 different R12 workshop manuals (Including the Renault R1170 manual) but all talk about the timing being 5 degrees (I think) below TDC. Hard to do if there isn't a timing mark.
    Ren
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Quote Originally Posted by REN TIN TIN View Post
    Guys.
    Ren
    The timing marks are on the bell housing. There is a little cut out to look into to see the timing mark on the fly wheel. The deg marks are on the side of the cut out.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    4,425
    Otherwise, you could set it at TDC and mark your own marks using the dimple (if appropriate location) and a white tyre pen on the timing cover.
    This is what I have on my R10 with 1397 and it has worked for 10+yrs. The only hassle for me is that the TDC mark is only visible from under the car.
    KB
    1000+ Posts Frans's Avatar
    Auckland
    1,554
    I've never had a 12 but the R5 and 16TS are the same being on the bell housing. What bothers me (if I understand it right) is the fact that you have to set the timing 5deg after TDC. Maybe they mean BTDC (before) and not below?
    It is safe to start at 8-10 deg BTDC and work from there.
    Regards.Frans.
    Old enough to know better
    Young enough to do it anyway.
    1000+ Posts driven's Avatar
    Apr 2005
    1,564
    Some distributor curves were set at ATDC.
    Check your distributor designation - numbers for correct value
    4,425
    I'm pretty sure one of my R12 manuals talks about 0 or very low degrees BTDC timing also. I remember thinking it was low as I'm used to cars with 10-15 deg BTDC.
    KB
    Brisbane/Australia
    2,199
    Thanks guys,
    I must be getting old or there's been too long a gap between R12's I've owned.
    I remembered about a hour after I posted that the timing marks are on the flywheel.
    I shall go away into a corner and hang my head in shame.
    Ren
    Nov 2005
    Geraldton
    1,634
    No. Go into your garage and set the bloody timing!
    In the Shed(s):
    In the Past:
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,531
    So I'm still confused With a fancy gun (measures rpm) I found a shady spot firing into the window on the top of the bell housing, and.. what should I be seeing? *ducks*
    I'm used to bits of white, or chunks of metal missing, but it was a bit difficult to distinguish where the mark was, or wasn't :S I'm further assuming 12 o'clock is TDC, are there degree reference marks cut out on the face of the flywheel one can measure against? There are no reference marks viable on or around the cut out in the bell housing I could distinguish...
    #fails.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    #fails.
    There is a cut out in the flywheel which is easy to see, I just use tipex or white paint to high light it.
    Which spark plug lead did you attach your timing light to? #1 cylinder on a Renault is at the flywheel end, not at the radiator end which gets a few people.
    Also the method I use to find TDC on the sierra engine is to remove the spark plug from #1 cylinder (the one closest the flywheel) turn the engine over in a clockwise direction looking from the front of the car using a 19mm ring spanner on the crankshaft pulley and put my finger over the spark plug hole until you feel that cylinder come up on compression and then look in the window to do the last few degrees of adjustment.
    From memory the largest mark is TDC, sometimes they have numbers cast into the bell housing.
    This link explains it ok.
    | Repair Guides | Ignition Timing | Timing | AutoZone.com
    Regards Col
    1973 Alpine A110
    Aug 2002
    3,531
    2 things;
    1) great advice re spark plug out and fine tuning,
    2) and no I hooked it up to cylinder 4, radiator end
    Thank you Col!
    Simon's Avatar
    6,203
    #fails.
    Being an early car, it may not have the marks at that end, the marks being on the crank pulley and the pointer on the timing cover. (See first pic)
    The mark at the flywheel end being a chunk out of the flywheel which lines up with the marks on the bellhousing. Turn the motor over until the rotor arm points to No.1 and then see if the cut on the flywheel is visible, then mark the flywheel with paint - the dark chunk then being more visible. (See second pic)
    Attached Thumbnails Attached Thumbnails R12 Timing-dsc08912.jpg   R12 Timing-dsc08913.jpg
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Perth Western Australia
    2,705
    Vacuum gauge. Oh no not this again!
    Tap into the manifold or base of carb. Obtain highest reading on gauge,, usually 20. Then turn the distributor back around 18.
    Timing will be as near as.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Yes this is one way of doing it.
    Another way is to drive the car in top gear at about 60 Km/h keep advancing till engine pings and then retard to last point it did not.
    Regards Col
    1973 Alpine A110
    Auckland
    1,554
    Timing can be set using no.1 or no.4 it won't make a difference. Maybe the timing is so far out that the mark has disappeared behind the bell housing. Remember that seeing from the flywheel end the rotation is CCW.
    Frans,
    Aug 2002
    3,531
    Well it sounds like I was looking in the wrong place for the mark. As Simon indicated it is actually on the front pulley, (mine is an early one)
    And 1 or 4, wont make a difference? Firing order is 1342, perhaps I don't understand how a timing gun works :S
    And it's running really well, I'm just giving it a once over before I drive it 865km's
    Auckland
    1,554
    Yes 1 or 4 will give you the same reading. It has to because the timing mark is at the same spot when 1 fires and a full rotation later no 4 will fire. When you have completed your timing on 1 do a test and put the timing light on 4 and see the results.
    Aug 2002
    3,531
    2 rotations of crank, 1 rotation of cam, 4 stroke cycle.
    Ah, I understand.
    9,315
    Guys.
    Ren
    Just wanted to remind you dwell is not going to say anything about the timing of the spark.
    Timing issues have been well and truly covered.
    Remember to disconnect the vacuum tube to dizzy and plug the intake end.
    ACHTUNG ALLES LOOKENPEEPERS
