R10 gearbox, 16 internals
Results 1 to 18 of 18
    4,425
    Default R10 gearbox, 16 internals
    I have a gearbox out of one of my R8's that supposedly has "R16 internals"
    What I want to know is typically what parts are from an R16, and what are std 8/10.
    I believe the diff, spider gears etc are 16, but my concern is buying parts for the refurb. What are things like the synchros likely to be from?
    Where's the best place to get bearings, synchro rings etc etc
    Anything else I need to know?
    KB
    Oct 2012
    601
    Bearings are easy enough, the usual suppliers will have them. The R16 manual lists some strange French number for one of them, my donor box had a different one, French again. There is an equivalent for it. I would not touch the bearings on the secondary shafts if you can avoid it.
    If it has R16 internals then it's pretty much everything other then the input shaft and the selector shafts.
    It should have larger splines on the diff needing modified u joints. It should have the diff spaced out as the R16 one is 11mm wider. The casing should have also been clearanced as the crown wheel is larger.
    I haven't put mine back together yet, so if you find info on the syncros I'd be interested.
    I
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,777
    8&10,
    If the conversion was done properly, the entire inside of the box is 16TS ??????
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    11,305
    Lucky man, if it is correct! I think you'd expect to see a external spacer ring on one side between the trunnion carrier/u-joint housing and the alloy gearbox housing if it is 16 internally, as the crownwheel and carrier is a wider unit and offset further sideways with respect to the pinion. Something like that. Colliers do/did that sort of conversion I thought and Dauphproto. Alan Moore's "NOT 750" has one too I seem to remember, so he'd know.
    Be interested to hear more.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    4,425
    Yes, I believe it has the spacer ring.
    The conversion was actually done by colliers. I think Bruce himself did it. The gearbox was in a yellow R8 that he prepared as a bash car for a customer. When they were done with it after doing a handful of bashes, they gave it back to Colliers who stripped it and disposed of the body - it was quite rusty by this stage. The box found its' way into a red R8 belonging to another customer, then ultimately to me when I bought the car off Jim Coleborne about 6 years ago or so ago.
    Yes, I could ask David Collier of course but I was trying to suss it out through here first.
    KB
    KB
    Ipswich, Queensland.
    1,963
    The whole 16 innards would be fitted to your R10 housing. I guess you could use the 16 crown wheel and pinion, with the R10 gears, but why would you when the whole R16 shafts and gears fit straight in, with only the diff being too wide, and the output sunwheels having a greater diameter.
    In the bearings, the pinion bearing is the one that gets most worn, and of course takes the most effort to change.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    11,305
    KB
    Lucky bugger. Can I have first refusal please?
    Traralgon,Victoria
    209
    Rob Sealy did my box and I supplied the 16TS internals thanks to Ray(Geokoeng). The conversion bits i.e spacer,gaskets e.t.c and big uni's came from Steve Swan.The only part Rob rejected was the pinion bearing which I sourced from Mecaparts.
    Brian
    Ove
    Ove is offline
    Germany
    69
    I have a gearbox out of one of my R8's that supposedly has "R16 internals.
    ...., but my concern is buying parts for the refurb. What are things like the synchros likely to be from?"
    Things are not so easy as there were some evolutions at the R16 336 gearboxes. The 'R16 internals' might use the early synchron rings like the R8 for 1st and 2nd gear or newer ones with a different angle (6į 40' or 9į). You either have to check their design or count the cogs of the pinion to analyze the 'R16 internals' in your gearbox.
    Ove
    4,425
    So the good news are that the synchros and bearings all seem OK so will not be changed.
    There is a question mark over the uni joints however, or at least the races in them.
    Someone above mentioned that they are modified regarding the splines etc.
    But if I had to replace the actual uni joints themselves, would they be R10 or R16?
    And given Steve has pulled up stumps, where best to source from?
    KB
    KB
    Perth, WA
    1,777
    KB,
    For all of Steve Swans information from his sight, go to turborenault.co.uk into the Technical section and go to 8 Gordini Workshop. He tells you the size of the units, and then you phone your local Drivelines or Hardy Spicer agents and give them the size and they will tell you what matches. I use an Alfa model from their books for my conversions. Have not had to do rebuilds yet. It would be good to measure yours as well, diam of bearing cup and distance face to face on outside of cups.
    Ray
    Ray geckoeng
    Boonah Qld
    2,637
    You could try a farm machinery supplier. I have been told that there is a very wide range of uni crosses available. If the splines are gone then they probably couldn't help you.
    4,425
    Mmm. Only one uni joint needs replacing. I can see that one side of the yoke has been machined to suit the R16 outputs, the other is std r8/10 that fits the axle shafts. The uni joints seem to be held in with a metal disc spot-welded in three places each rather than a circlip.
    I may be best seeing Dave Collier and get him to replace the U/J - may be less mucking about in the long run.
    KB
    1000+ Posts Frans's Avatar
    Auckland
    1,557
    Then it will be easy to grind the spot welds off with a rotary file, replace the u-joints and spot weld them again. The spot welds are there purely because it is a pain to clamp the one half of the u-joint in a 4-jaw chuck and center it up in the lathe and cut a cir-clip groove.
    Frans
    Old enough to know better
    Young enough to do it anyway.
    4,425
    I dropped the UJ assembly off this morning for Dave to change the UJ.
    Apparently it is some kind of GM, maybe early torana so should be easy to get.
    With the shed packed up and in storage, it's not worth my while trying to tinker with it at present.
    KB
    11,305
    Do you really want it?
    4,425
    Can you pick it up by the end of the weekend John?
    Yes, I think I want it but thanks for the offer.
    KB
    11,305
    I could fly over tonight.....
    Ah well, if I can ever help you out....
