R8G wiring question
Results 1 to 8 of 8
  • 1 Post By COL
Thread: R8G wiring question
    Fellow Frogger! Paul T's Avatar
    Mar 2012
    Bathurst, NSW.
    263
    Default R8G wiring question
    Here is one for the brains trust.
    Can anyone identify the wires in the photos. They come in the main loom to the battery area. There are 5 wires-
    * 1x grey.
    * 1x White.
    * 1x off white or cream.
    * 1x Yellow.
    * 1x Pink.
    Also the driving lights come on with the low beam. I have swapped the wires over on the switch but still the same and the wires to the lights are correctly connected.
    Thanks for any help you can give.R8G wiring question-20151209_122756.jpgR8G wiring question-20151209_122818.jpg
    Paul Tomlinson
    R1135 Gordini 1968.
    Jaguar XJ-C V12 1975.
    Alpine GTA- ATMO 1987.
    Jaguar X Type 2002.
    10,703
    Sorry, really can't help with that. But I'd change the rubber hose!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Mar 2012
    Bathurst, NSW.
    263
    Have you got one? I have been looking but can't find one. I have something similar but it doesn't look right and is hard to bend to shape.
    Paul Tomlinson
    R1135 Gordini 1968.
    Jaguar X Type 2002.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,953
    Quote Originally Posted by Paul T View Post
    * 1x grey.
    * 1x White.
    * 1x Yellow.
    * 1x Pink.
    Thanks for any help you can give.Click image for larger version.
ID:	77919Click image for larger version.
    Hi Paul
    Here is a wiring diagram from another 8G thread. Post #8 has the wiring diagrams in it.
    R8G Wiring Diagram
    Hope it helps a little.
    Paul T likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    10,703
    Alas no. But I think a rummage at a place selling silicone hoses, plus a short length of metal pipe, might turn up two hoses that work with a spacer between them. I know where to go in Perth but that is little help. Best wishes for it. I see Col has come good with advice!
    Renault 4CV 1951
    Renault R8 1965
    Traralgon,Victoria
    205
    Hi Paul, I stuffed around for ages trying to solve exactly the same problem with the driving lights but can't for the life of me remember what I did to fix it.I do recall it wasn't the switch but seem to recall it was the relay wiring.Hope Col has come to the rescue! Cheers Brian
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,618
    HI Paul, the 2 items you are looking at are the alternator regulator and a relay for the Cibie Spots in the centre. Of course the diagram is mirror image for the RHD car, and comes from the LH front "a" pillar across the front firewall (inside) to the steering and then out through the RH front firewall and mirrors the first "LH page".
    Not sure what all the white wires are for.???
    Is it a new loom???
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Perth, WA
    1,618
    The wiring in the front of Graeme's G
    The regulator on the back of the battery box is gone, with the Suzuki mini alternator with built in Regulator. All lights are on relays and a spare unit for Fog Lamps if required, and all fused at the front, as well as fuses controlling all the dash and steering column.
    R8G wiring question-rebuilt-front-sml.jpgR8G wiring question-rebuilt-front-lh.jpg
    Ray geckoeng
