Stuck half way! Temp Guage on R17
Results 1 to 11 of 11
Like Tree3Likes
  • 2 Post By COL
  • 1 Post By Shoji
Thread: Stuck half way! Temp Guage on R17
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,074
    Default Stuck half way! Temp Guage on R17
    Help! Stuck half way! Temp Guage on R17. It was like it when I bought it and only travels 1/4 up to the red zone. But it's not overheating. Just the Guage is jambed at half when cold.
    How can i fix this. Tried the earth out trick with the wire from the sender unit. Sender unit is fine. Any ideas would be appreciated.
    John
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,973
    I would say there is something wrong with the movement in the gauge.
    If you have a real steady hand and lots of patience you could try to dismantle and see what the cause is, and try to fix.
    Another way is to find a good replacement gauge and just swap.
    An easy option is to buy an after market gauge and install in the car.
    The most expensive option it to take it to an instrument fitter and have it repaired.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jan 2012
    Mandurah WA
    1,074
    Thanks Col. I was thinking of removing it and having a look. Someone said to me that it may have been caused by a short. But I think your right, the only way is to check it internally. I love fine work so this will be a challenge. Another job on the list to do. Cheers!
    Brisbane/Australia
    2,032
    Not sure if I'm reading this correctly but are you saying the needle is at halfway when the motor is cold and goes from half to 3/4 when it warms up?
    If so, does it go to zero when the ignition is off or just when the ignition is on with a cold engine.
    If it's a half all the time including when the ignition is off, someone may have pulled the needle off in the past and it was reattached in the wrong position.
    The fix would be to pull the needle off (very carefully) and reattach it so it's pointing in the correct position when cold.
    It probably just an interference fit so the hardest part of the job will be getting the instrument cluster out.
    I didn't ever take apart the gauges on the 17 when I had it but I have pulled apart the Jaeger gauges in one of my 12's and by memory the needles just pull off but they are tight.
    If it goes to zero when the ignition is off and moves to half when the motor is on but cold it could be the wrong temperature sender (resistance is wrong).
    Ren
    Jan 2012
    Mandurah WA
    1,074
    Hi Ren.
    Yes I thought my explanation may have not been clear enough. So, your right in asking, when the ignition is off it does stay halfway!! You have answered my question with what needs to be done. I didn't think about the needle re-position. Great idea. I was going to try and dial it back manually or see if there is an adjustment screw. We do have an instrument guy that is local if i have doubts doing it.
    John
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,973
    Quote Originally Posted by Shoji View Post
    Hi Ren.
    John
    When you have set it back to zero you may want to check its rough calibration by putting the sensor in a jug of hot water and a thermometer while using some small alligator leads to jury rig. You want to make sure its into the red before it actually boils to be on the safe side.
    Shoji and JohnW like this.
    Regards Col
    1973 Alpine A110
    Armidale
    2,286
    However, don't forget that both coolant and cooling system pressurisation raise the boiling point, so would suggest 100C should be just at the bottom edge of red zone.
    Jan 2012
    Mandurah WA
    1,074
    Thank you Armidillo & Col.
    I will do my checks before heading off into the sunset, blind.
    Would anyone know the actual Ohm resistance value for the sender unit for the 807-10?
    I have just fitted a Covs universal one on my Mercury Outboard with an Ohm resistance level that was close but the gauge hardly moves. I need the correct one with the right level.
    John
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,356
    Does seem odd that both gauges failed within short time of each other..
    Earth all ok?
    Jan 2012
    Mandurah WA
    1,074
    Hi Bowie
    Not the case. I have just bought the car. They were already faulty. But I will at some stage get to this job.
    Trying to sus out a random tick, tick under the hood on the right side at acceleration when driving. Found a broken spring underside the fuel pump which keeps the shaft against the cam and repaired but it's not the sound.
    John
    Jan 2012
    Mandurah WA
    1,074
    Thanks, to all that helped. Temp gauge is fixed. I had the temperature checked when running hot using thermal infrared technology. All seems good with cooling system and I have cleaned the over flow bottle (nice clean & green fluid) and the pressure cap checked for functionality. And I have been driving everyday since I bought the car in early November and so there seems no problem with running temp. All I did with the needle was turn it to the cold. Checked and double checked. all seems to be working now. But gauge I have another on it's way just in case.
    Thank you
    John
    renaultmark likes this.
