Weird Renault 12
Results 1 to 19 of 19
Like Tree10Likes
  • 2 Post By David Cavanagh
  • 1 Post By mistareno
  • 4 Post By David Cavanagh
  • 3 Post By kiwia110
Thread: Weird Renault 12
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    Default Weird Renault 12
    This has to be the strangest looking R12 drive train set up anyone has ever seen.
    Attached Thumbnails Attached Thumbnails Weird Renault 12-1449441841037.jpg   Weird Renault 12-1449441859592.jpg   Weird Renault 12-1449441875019.jpg   Weird Renault 12-1449441892069.jpg   Weird Renault 12-1449441908158.jpg
    jaahn and JohnW like this.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Well to be a pedantic so and so, its not an r12...
    Feb 2001
    4,904
    But we don't have a Dacia forum
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,346
    Quote Originally Posted by David Cavanagh View Post
    Its a copy of the Sinpar R12's, except dacia used leaf springs instead of coils.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    493
    Dacia produced many 4x4 utes. Maybe it's from one of them.
    Henry
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
    1000+ Posts driven's Avatar
    Apr 2005
    1,572
    So chicken or the egg.
    Was Dacia first or Subaru
    Attachment 77855
    Feb 2001
    4,904
    It's actually not even Dacia.
    Another Romanian company called Aro (stands for Auto Romania) built the 4x4 system for Dacia to use in the 1304 pickup. It's extremly rare, my car being 1 of only about 2800 made. Most pickups were 2wd.
    In 2wd mode it's rear wheel drive with a dog clutch set up to engage the front wheels
    Here it is in it's early days working hard as our delivery vehicle.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,541
    That's great.
    Now give it 300hp and squeeze it all under a 12 / 15 / 17
    Your custom license plate could read,
    G0T-AR0
    Feb 2001
    4,904
    That's great.
    G0T-AR0
    With running gear as rare as this I'm more likely to go the other way and stick an 1100cc R10 motor in it.
    It'll stay original with a 1397cc but I'm using a weber instead of the single throat Romanian thing it came with.
    If I fully register it (probably go club plates) the rego will be DACIA.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    It'll stay original with a 1397cc but I'm using a weber instead of the single throat Romanian thing it came with..
    Yeah good thinking. Much easier to set the Weber up for the big Turbocharger...
    David Cavanagh likes this.
    16,758
    That's great.
    G0T-AR0
    You'd trash the driveline due to axle windup. It needs a center diff to drive on sealed roads with 4wd engaged
    Apr 2014
    kilsyth (lower montrose) vic,
    226
    hi Dave, your Dacia gearbox is a different set up to my Aro 10 in that mine uses a transfer box(consequently it has high/low range) at the rear of the gearbox and a short driveshaft (two r10 uni joints splined together) to a separate diff mounted under the bellhousing out via driveshafts to free wheeling hubs.Was r12 engine but fitted r18 with modified 16ts crossflow head into it,that was 18 years ago and never fired up engine.As vehicle has sat around since and body is rusting I sold engine, so it sits languishing with me hot and cold as to what to do with it. I had thougts of sitting my rusty floride body on it,as it runs the same wheel base,but there is not much solid metal left in the lower sections of the floride.Any way its third in line of projects. Jim
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,098
    Every day is a good day
    9,338
    I think R18 had a 4x4 version, is your contraption anything like the driveline in that, Dave?
    I think that R18 had more power than the R12, so perhaps pretty safe to up it a bit. I would be so tempted to stick a 12G engine in it like you can't believe. Needs some weight on the rear though.
    Oh, and Alfa 33 had a 4wd version as well (but I think that was FWD and dog clutch to the rear). Brilliant car, that.
    ACHTUNG ALLES LOOKENPEEPERS
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    As was stated earlier, the gearbox has no center differential so its only really suitable for low speed on loose surfaces. The thing would bind up and tear itself to bits driving on dry asphalt.
    The 21 quadra was a constant awd with a center split to the rear wheels built into the gearbox. Not sure about the 18.
    Feb 2001
    4,904
    When it was in daily service we were thinking of an 18. Wouldn't go 12G no way.
    Traction is quite bad even with a 1.4. Something with torque and low revs would be good.
    But......I know this may sound dumb and boring and most of you wont get it but I'm going to keep it standard and go with the 1.4 so under the bonnet it'll look like a Virage. Boring aren't I.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    Feb 2001
    4,904
    Quote Originally Posted by dacia4x4 View Post
    As far as I can tell this is made by Aro for Dacia. It's not an off the shelf Aro gearbox so that's why I'd like to be careful. We've rebuilt it once already, can't remember what happened but my clever brother dismantled it and found it was something from another planet so he rebuilt it using R12 parts.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    Sep 2004
    Tamworth UK
    624
    On this one I am with David, so rare it stays original.
    4,426
    Quote Originally Posted by kiwia110 View Post
    That's almost like a Yoda quote!
    Be Stars Wars fan, you must.
    KB
