R10 Shroud
Results 1 to 10 of 10
Thread: R10 Shroud
    Mar 2011
    Roselands
    253
    Default R10 Shroud
    Hi, can anyone tell me how to remove the shroud around the speedometer on the dash of the Standard R10. Not sure how it is secured and do not want to break it.
    Help
    Roger
    Oct 2014
    Windsor 2756 NSW Australia
    659
    As far as I recall, if you are talking about the rubber bit, for a RHD car first undo the two self tappers, one in the obvious position and the other hidden beside the ashtray. Then push/slide the rubber shroud about 2 cm to the left to release the tangs on the back that locate it on the metal dash.
    The flat piece with the wood grain is usually glued in and likely to be dried up and no adhesion after 40 plus years and can be carefully lifted off without bending it.
    I have no doubt there will be others here who will have more detail and a few pics or illustrations.
    Hope this helps
    Mar 2011
    Roselands
    253
    Thanks but not the rubber bit, know all about that fella, its the black plastic surround sits on the fake wooden dash. I am reluctant to tug on it in case it breaks. Any ideas?
    Mar 2011
    Roselands
    253
    R10 Shroud-7110_dash.jpgThis is the speedo I was talking about. nothing but speedo, black plastic sits on the front of the dash, behind the steering wheel
    11,292
    Quote Originally Posted by RENOSPRITE View Post
    Hi, can anyone tell me how to remove the shroud around the speedometer on the dash of the Standard R10. Not sure how it is secured and do not want to break it. Help Roger
    For a moment there, I thought you were going to bury it.
    I've no idea I'm afraid, the R8 having two exposed screws. Good that you are putting spare time to good use though. Double
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Oct 2014
    659
    OK that part has a nut on the back on each end that requires a 7mm spanner/socket etc.
    Good luck.
    Apr 2012
    geraldton, west aust
    54
    that's a flash looking dash with radio and an r10s sports steering wheel. where did that come from ?
    11,292
    Quote Originally Posted by skookumchuck View Post
    Do you want to buy a wheel like that? I've got one in Perth, not with that centre though. Make an offer! It's a 10S wheel I guess, 8S if you were in Europe.
    John
    Apr 2012
    54
    have one as a spare on my r10s. i have a later wheel fitted on. thanks
    Mar 2011
    Roselands
    253
    Default R10 should
    Found this one on Internet, a beautiful green car Was up sort sale some time ago in Canada I think, the dash looks different maybe a special I like hoe the radio fits in the dash too
