R8 & 10 disc dimentions
Results 1 to 7 of 7
    Dec 2004
    757
    Default R8 & 10 disc dimentions
    Could someone please post a picture with all the dimentions of an r8 disc as I'm away from home until xmas and don't have a manual with me and a friend from Tamworth is restoring an old sports car that has 3 stud solid discs that by the pic's look a lot like r8's
    cheers Peter.
    LIFES TOO SHORT TO DRIVE BORING CARS!
    11,292
    Quote Originally Posted by Peter J Kent View Post
    cheers Peter.
    Hi Peter,
    Can't oblige immediately but someone will. I can't think of any other solid discs with three studs from times past though unless it is new enough to have chanced on R16 discs. I vaguely remember that the R8 Gordini discs are thicker but fit anyway (6mm and 7 mm maybe).
    I can check an old one in a day or two if no-one comes good.
    And WHAT is the car please?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Oct 2012
    601
    I don't have an R8 one handy, R10 I do and they should be the same. 261mm diameter, 6.5mm thick
    Attached Thumbnails Attached Thumbnails R8 & 10 disc dimentions-1447583965317.jpg
    Simon's Avatar
    6,203
    Post a pic of the subject hub, it'll get a faster result.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2005
    rosevale/tasmania
    2,870
    so, what is the sports car?
    cheers! Peter
    Dec 2004
    757
    I'm not sure peter I've not seen it as yet he just rang me asking for has emailed me a drawing of the disc i'll try and get it up on here
    cheers peter
    Last edited by Peter J Kent; 16th November 2015 at 07:28 PM. Reason: add a picture
    Dec 2004
    757
    I've just tried to upload the pictures with no luck so I will try and relate them as best I can
    outside diameter 261mm
    inside diameter 60mm
    recess in back 115mm
    thickness of disc 6.5 mm
    offset from front face of disc to mating face at hub 33mm
    hope this helps thanks peter
