I am puzzled!
Results 1 to 13 of 13
Thread: I am puzzled!
    Sep 2004
    Tamworth UK
    618
    Default I am puzzled!
    In amongst the small mountain of parts which came with the 5 Gordini there are a pair of front uprights with hubs. These are front wheel drive, but here's the query, the stud spacing is not the same as 5/12 etc. It is bigger, more like the stud spacing found on an 8!
    What could they be?
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,960
    The stud PCD of the R8/10/12/15/16/17/18 are 3 x 150 mm
    The stud PCD for the R4/5/6 is 3 x 130 mm I think
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Sep 2004
    Tamworth UK
    618
    Thanks Col. I am even more puzzled now, as the 5G uses R12 brakes, and they appear unmodified. The Group 2 uses, of course you guessed it, the 15/17 ones. You are right about the 130mm.
    Perhaps the original rotors were supplied as blanks and drilled to suit the 130mm spacing. Hmmmmm
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,960
    Maybe the 5G had the bigger brakes from the R12 and hence the 150mm PCD.
    Will have to wait for Simon to spot this thread and give us the real story.
    Regards Col
    1973 Alpine A110
    Simon's Avatar
    6,139
    Quote Originally Posted by kiwia110 View Post
    The part number in the catalogue for disc brake 5 Mk1s (including the 5A/G) is identical to the Renault 12 non-vented front disc. So no drilling of blanks needed. :-)
    Any chance of a pic of the mystery front hubs? I'd guess the answer would be up in a jiffy!
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Sep 2004
    Tamworth UK
    618
    Photo done, as you can see it looks like a wishbone type set up. I don't have a good memory of the 12, but wasn't that a bit different to account for the long spring? The 5G has the smaller stud spacing than a 12.
    Interesting that your listing comes up as that Simon, as when I went to sort pads the "standard" 5 ones were nothing like the ones on the G. It wasn't till we went down the line of looking at 12s, just in case, that we came up with the correct pads. As you say the part number is the same, what would account for the 130mm stud spacing? I am in no way doubting you, just puzzled!
    Simon's Avatar
    6,139
    I just thought I was very lucky to have been given the Renault 5 Mk1 microfiche (among many others) a few years ago.
    So, I guess it depends on what you are calling the rotor. I call that the disc part, the one that gets stopped by the pads. That is the part specified as being the same as a non-vented Renault 12 brake disc. The part that the disc bolts to, which is splined for the driveshaft, I call the wheel hub, which is bespoke 5A/G (with the 130mm PCD). Even though the wheel bearings are the same dimension as those on the late Renault 12, (35 x 72 x 17), for the 5A/G they have a different unique part number which likely indicates a different material spec.
    1963 Renault R4 Van
    1964 Renault R4
    Sep 2004
    Tamworth UK
    618
    Ok Simon so that we are clear, I normally use the word disc, but was told on this site years ago that they are really called rotors, so you and I would normally call them discs
    The wheel hub we use the same words. On the 5A/G they have a much larger driveshaft diameter and splines size than the garden variety 5 which would explain the different part number?
    What I had totally forgotten is where the disc bolts on. My dumb memory forgot that unlike most cars the wheel studs do not pass through the disc,
    None of the above resolves what the hubs and what I call uprights are from though. Any ideas?
    Simon's Avatar
    6,139
    Any ideas?
    Oh, Renault 12/15TL, LHS. It needs turning over to tell whether it is early or late.
    1963 Renault R4 Van
    1964 Renault R4
    Boonah Qld
    2,506
    I agree they are disc's. Drum brakes have drums and disc brake have discs. Rotors, where does that come from U.S.A?
    Sep 2004
    Tamworth UK
    618
    Thanks. That turns them into scrap.
    10,705
    Dunno. I think I first heard them referred to as rotors was the time our Peugeot 306 needed new ones, perhaps 12-15 years ago.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Boonah Qld
    2,506
    If you type "rotors and brakes" into the web it refers you to disc brakes.
