R8 tight handcrank... slow turnover with starter ...
Results 1 to 25 of 37
Like Tree4Likes
Thread: R8 tight handcrank... slow turnover with starter ...
    Fellow Frogger! forzamacchi's Avatar
    Oct 2013
    Los Angeles, United States
    235
    Default R8 tight handcrank... slow turnover with starter ...
    Hello All,
    I finally buttoned up my R8 enough to give it a go... I noticed it was very slow to turn over and drained the battery quite quickly. I also cranked it over by hand and found it to be very tight. There is also a dull rubbing sound as it turns. Not a metal on metal sound...but almost rubber on metal.
    My only thought is that perhaps the crank seal isn't seated correctly and rubbing against the flywheel?
    I installed new seals all around.... had the valves redone and installed a new clutch. Hardly a majorly invasive surgery. Thoughts? Cheers, Ben
    Simon's Avatar
    6,203
    Unlikely to be a crank seal, they wouldn't hold an engine tight regardless of how badly sized or incorrectly fitted they are. For peace of mind, it sounds like engine out time, then turn the sucker upside down on an engine stand. It could be a multitude of different things. Tight or incorrectly marked main/conrod bearings, tight or incorrectly marked pistons, tight piston rings with no gap.......etc etc....
    On the bright side, it could even be an easy fix like a tired starter or, poor earth, poor connection or tired battery, it depends on what you call tight when turning it over by hand :-)
    Things are going to have to be diagnosed by a process of elimination.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,339
    Quote Originally Posted by forzamacchi View Post
    Hello All,
    Remove the spark plugs and try turning it over with the crank handle, should turn over easily.
    I had problems with a main seal in my Virage about 13 years ago causing a horrible noise after an engine rebuild, I ended up changing the seal.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Oct 2013
    235
    Hello Simon! Pistons and Conrods were never removed. This was solely a valve job and seal redo..... I am giving her an extra long charge right now....we'll see what happens... Ben
    On the bright side, it could even be a tired starter or battery, it depends on what you call tight when turning it over by hand :-)
    Simon's Avatar
    6,203
    Oooo.... So what was the history of the motor before the head job? It could also be a multitude of other things. Try Col's suggestion of pulling the plugs, and see what goes.
    1963 Renault R4 Van
    1964 Renault R4
    Oct 2013
    235
    The history before the head job is that it sat for nearly 40 years and has about 73,000 miles on the odometer....... But other than that it ran amazingly except for the incredibly weepy seals.....
    11,305
    That is the important comment - you had it running well immediately before dealing with the head and the seals. There will be friction of course but.... I found after my last engine rebuild, so with maximum piston and ring friction before running in, that I could spin it well enough on the starter motor with the plugs out to bring up oil pressure before I started it for the first time.
    Did you use the correct bolts for the flywheel re-attachment to the crankshaft? Is something very wrong with the fan belt, alternator and water pump? I had a water pump stop dead a couple of months ago, with much squealing of belts, blue smoke etc before I stopped and worked out the problem (on the Citroen, not the R8).
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Newcastle
    2,805
    Hi
    This has no reason just a wild guess as you are puzzled. You may have incorrectly fitted a longer bolt in a place where it is just contacting some soft item behind.
    Double check any potential places. I have even seen an incorrect long bolt fitted into an engine which locked the camshaft.
    Good luck Jaahn
    It's how I roll...Brisbane
    33,972
    Could it be rust on the inside of the cylinders causing friction...?
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    11,305
    Hi
    Good luck Jaahn
    Yes, just this week a friend locked up a Dauphine Gordini motor this way, with a slightly over length bolt through the flywheel.
    Something like that is my best guess too.
    11,305
    Quote Originally Posted by 59 Floride View Post
    Doubt it, as the motor was running well before being partly dismantled to fit seals. I'd like to be there and feel it on the crank handle.
    Oct 2013
    235
    This sounds like a good option.... Now which one could it be...hmmmmm
    Hi
    Good luck Jaahn
    Oct 2013
    235
    John,
    I made sure the cylinders had wd40 or some kind of lube to inhibit rust and I regularly cranked it over. There were a few times where they were locked, but it busted free with a little prodding. The four bolts on the flywheel were the original pieces. All others were replaced due to corrosion. Any thoughts on which bolts may be causing the rubbing? Ben
    Oct 2013
    235
    I will see if I can record the sound when cranking over the engine tonight. I am also going to disconnect the belt to rule that out. Also, I also had the cross member powder coated. This is connected to the rest of the body through a grounding wire (see pre powder coat photo) . Should I scrape back some of the powder coat at the hole to ensure proper grounding? Also, I don't remember a ground wire to frame coming from the coil. If the coil holder is painted would this make a difference? I am running a pertronix electrinic ignition. Finally, when I crank over I am not getting any fuel being drawn into the pump. Do I need to prime the system somehow? Cheers in advance... Ben
    4,425
    Those earth questions would be a good place to start I think.
    KB
    Newcastle
    2,805
    Default sort your problems before starting !!
    Hi
    My . If you have noticed a problem on reassembly, then sort that BEFORE you start the engine. If there is something rubbing or binding or whatever, starting the engine will only wear it away as a solution to stop the noise ?? Bad solution !
    As Col suggested earlier, pull the plugs and hand turn it. It should be free and turn easily. No noises from rubbing etc. If not then sort it by elimination before the next step. This is reassembly 101.
    Then you can look at starting the engine. Priming the carby is always a good idea. Having good earths is always a good idea.
    Jaahn
    Newcastle
    2,805
    John,
    Hi Ben,
    Not having worked on one of these motors for a loong while I am guessing.
    Did you replace the flywheel to crankshaft bolts x5 ? If so were the bolts EXACTLY the same length as the originals. There is not much room behind them !
    Was the seal driven in square and fully home. Not much room there either !
    Jaahn
    Oct 2013
    235
    Hello Jaahn.... The bolts were the exact same.... They were in quite good shape..... The rest of the bolts..no.... I replaced all but the two long at the top that match the bell housing to the engine.... Ben
    Hi Ben,
    Jaahn
    11,305
    Hmm. Jaahn has said it all really. This must be something that will be very obvious with hindsight.
    Did the engine mate up fully with the transaxle before you tightened the bolts, or did you have to use the bolts to pull it in? It should slide the whole way. I once had this trouble fitting a later R10 engine into an early R8 transaxle and it locked solid, but never actually would mate up fully.
    You need a fuel pump "avec levier" for priming a car like this that isn't driven a lot. They are well worth buying.
    Good luck as ever.
    Oct 2013
    235
    Hello John... The transaxle mated correctly... It took a few times, but it slid in completely. ... I am going to remove the sump as well and make sure nothing is rubbing as I crank it over. I doubt it could have happened, but I want to make sure a conrod didn't get bumped and fouled. Already dark here, so it will have to wait for another day... Thanks for the encouragement! Ben
    Good luck as ever.
    Nov 2005
    Geraldton
    1,636
    Hi Ben
    You'd expect the compression to be higher with a reconditioned head and ergo harder to turn.
    Does the engine spin more freely with the plugs out?
    What was the result of attempting to turn the motor over with the fan belt disconnected?
    Can you turn the fan and the generator easily by hand?
    Did you replace the bolts that secure the fan to the water pump pulley?
    If you suspect there is an earthing issue run a jumper lead from the negative post of the battery onto the motor.
    Also check that the +ve cable to the battery is on properly.
    We'll get there...
    P
    In the Shed(s):
    In the Past:
    11,305
    Don't pull the sump off until you've done everything else you can think of. Take on Exfrogger's suggestions first! He's just up the road from us, about 400 km that is.
    Are you confusing it "bouncing on the compression" with a crank handle with stiffness?
    As he said, "we'll get there".
    Box Hill, victoria
    69
    How come no one has mentioned engine timing???
    I meant ignition timing!
    Feb 2005
    rosevale/tasmania
    2,873
    I have nothing substantive to add to the comments & suggestions of more learned colleagues but I do have one meta observation. This thread manifests nicely one of the better features of A.F.: the ready collegial availability of thoughts & ideas (& sometimes bits & pieces) on almost any topic likely to arise concerning our frog beasties.
    bonne chance! Peter
    Oct 2013
    235
    I wholeheartedly agree.. I would be up a creek without a paddle if I didn't have AF as a forum. This is the first car I have ever attempted to work on..... and at no time have I ever been discouraged to ask another question.... for that I am grateful!
    I will do some testing tonight, though my time is being compressed because I will be in Hawaii 3rd-16th of next month... unfortunately for work. Cheers! Ben
    bonne chance! Peter
