Mystery brakes on R12. What do I have?
Results 1 to 17 of 17
    Fellow Frogger! keith mcelroy's Avatar
    Sep 2004
    ballarat
    249
    Default Mystery brakes on R12. What do I have?
    Hi all,
    I have decided to refresh the brakes on my R12 while waiting on a refreshed engine. My Renault brake knowledge, such as it is, starts and finishes with the R8, R8G, R10, 10S family.
    In my ignorance I expected to see a solid disc at the front, of about 10 mm thickness. What I have is a vented disc of 20 mm thickness and an unfamiliar calliper (I'm guessing aftermarket but don't know new-fangled Renault after the 60s!).
    The car has had at least 3 prior owners and a hard history in S.A. of doing more than going to the shopping. This set up could date from anywhere in the last 30+ years.
    Does anyone recognise what I have?
    Thanks, Keith
    Simon's Avatar
    6,203
    Renault 15TS/17
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Like Simon says they are R15TS/17TL/17TS brakes. The calipers are Bendix. They are nothing special, just the standard upgrade the lots of people do to their R12's
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Sep 2004
    ballarat
    249
    Thanks Simon & Col. That makes life simpler in the search for bits (and a reasonable choice for a car getting closer to 12G replica outfitting).
    Keith
    Simon's Avatar
    6,203
    Quote Originally Posted by keith mcelroy View Post
    Keith
    And if no one recalls a Renault 15TS/17 in the model search, just say they are 12 Gordini, as all those models use the same front brakes.
    1963 Renault R4 Van
    1964 Renault R4
    Sep 2004
    ballarat
    249
    Why the DBA on the caliper?
    Is this the Australian brake mob DBA? Was it part of upping local content? Would have been early in the DBA history if this is so.
    Simon's Avatar
    6,203
Name:	12G caliper.jpg
    DBA Lockheed as opposed to Disc Brakes Australia, which are different firms.
    1963 Renault R4 Van
    1964 Renault R4
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Sorry about that for some reason I had Bendix in my head. Go with what Simon said
    They are also 54mm in diameter if you need to buy seals for them.
    Make sure that the seals are not for the smaller 48mm R12 calipers
    Regards Col
    1973 Alpine A110
    Sep 2004
    ballarat
    249
    Thanks again, guys. Instant and informative. My education continues...
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    R15/17 were not assembled here. All cars are fully imported so no local content.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    dvr
    dvr is offline
    754
    If you or anybody else wants to sell a pair of those mounting brackets please contact me.
    Sorry, don't want to hijack your thread but the photo clearly shows what I can't find.
    Oh and if you decide to rebuild them, mark them first as they're paired, you'll need to make a wedge or spreader bolt to open the steel outer jaw enough for the alloy caliper piston to slip out. Think carefully about that though because there could be too much corrosion that once cleaned the jaw no longer pinches the piston part tightly enough. There's also a spring loaded lock pin that can be corroded and won't co-operate.
    Simon's Avatar
    6,203
    Quote Originally Posted by dvr View Post
    Just the cast iron brackets without the calipers? This may be a useless reply, but I'm pretty sure I've got a pair, but will have to check tomorrow night. They came off a 17TL 25 years ago, and I can't recall if they have been moved on or not.
    1963 Renault R4 Van
    1964 Renault R4
    dvr
    dvr is offline
    754
    Yes it's just the brackets that I'm after. I've got the calipers.
    Simon's Avatar
    6,203
    As I had sort of earlier anticipated, I later recalled that it was one that had actually found another home. So I've found the other one, it's available if you want to take a chance of finding another one or two later on......
    1963 Renault R4 Van
    1964 Renault R4
    Dec 2004
    757
    Where do reno 18 gts brakes with 3 studs fit into the scheme of things are they the same?
    LIFES TOO SHORT TO DRIVE BORING CARS!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Quote Originally Posted by Peter J Kent View Post
    I think they are pretty much the same as the R12.
    Regards Col
    1973 Alpine A110
    dvr
    dvr is offline
    754
    PM sent
