Fuego 2.0 Clutch Pushrod Alignment
Results 1 to 17 of 17
Like Tree5Likes
  • 1 Post By mistareno
  • 1 Post By Kenfuego
  • 2 Post By mistareno
  • 1 Post By addo
Thread: Fuego 2.0 Clutch Pushrod Alignment
    Don't remind me!
    16,609
    Icon11 Fuego 2.0 Clutch Pushrod Alignment
    Surely this isn't how they're supposed to be?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    The nylon bushes in the lever arm are gone allowing the arm to twist up. I had mine replaced with a self lubricating brass bush. It made the clutch alot smoother and lighter.
    Don't remind me!
    16,609
    Thank you! I assume the bushing was bespoke.
    19,225
    Addo, Shorlube make a big range and you may find something off the shelf.
    http://www.blsystems.com.au/PDF/SHOR...0CATALOGUE.pdf
    For a relatively non critical application like this you may be able to "stack" two bushes
    8,486
    There is a realy good parts fuego going onto the market now.
    Has that and every other part you might want and then some.
    Jo
    Don't remind me!
    16,609
    Found the thread about a porous bronze bushing:
    Fuego Clutch pivot
    8,486
    This is odd.
    Clearly I know my fuegos, but I have never seen a nylon bush, and every one i've pulled out or messed with has been a solid metal bush, probably aluminium.
    Maybe the reputable repairers just replaced them with solid bearings as a matter of course.
    Jo
    Don't remind me!
    16,609
    Maybe so! You can see the pictured one is clearly not right, there is wasted motion and lotsa friction with it.
    8,486
    Whilst I look at that image, I wonder where the little metal cage is that stops the loom rubbing on the fork???
    I suppose your next comment will be ....'What little cage'??
    Jo
    Don't remind me!
    16,609
    LOL, it didn't look right there either. I could see nascent chafing.
    Oct 2002
    Melbourne Victoria
    12,687
    Enjoying the thread. I will try and locate the mechanism that has been pulled out of another Fuego and measure that up Addo, The original bolt has a stepped configuration, the thread of the bolt that screws into the aluminium crankcase is smaller than the diameter of the bearing surface, I don't think from memory that any of the ones that I have pulled apart had a nylon bearing fitted.
    I do agree that the tilt of the bellcrank indicates wear and misalignment or else the bolt needs tightening carefully, it is a fine thread and easy to strip, so be careful. A self lubricating bronze bush if it can be accommodated would be an ideal modification. I will see if I can post a few pictures tomorrow.
    Ken
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    This is odd.
    Jo
    These are the factory bushes from a really low k Fuego.
    There are no guarantees they were the same on all modes. They are a hard plastic/nylon.
    Here are all the components.
    addo likes this.
    Don't remind me!
    16,609
    It's a helpful picture, thank you. I can now say the bolt the is most likely original, the upper steel flat washer not so, and internal bushes long departed.
    Would be a good candidate for a thin wall bronze bushing although the flange of a metal bush may be too fat, requiring a steel flat washer either side in lieu.
    Oct 2002
    Melbourne Victoria
    12,687
    Icon14 Making new nylon bush for Fuego clutch Bell crank
    Decided to challenge myself and get back to some Fuego business, searched around among the odds and ends of Fuego's that I have pulled apart.
    Found a Bell crank and also the stepped bolt and the thin shim spring washer, that I assume goes between the 22mm Hex and the upper nylon bush, yes it was there but the lower nylon bush as shown in Mistareno's post was lost in storage..
    Now what does one do, I measured up the dimensions, noted that the metric thread was 0,5 pitch with an outside diameter of 0.3125 (close to 5/16th of an inch- and that seems to convert to metric 7.9375 according to the card in the imperial 0-1inch micrometer.
    I also checked the size of the nylon bush and decided that as I have some nylon bush material and a small lathe I would make one up the same as the sample bush, as it appeared quite a good working fit in the crank
    The Nylon is a bit fiddly to machine with the tool to get a fine finish, finished the outside to sample size with the flange the same size at the material, then drilled the centre out almost to finished size, then bored that internal size to the bolt diameter - bit lucky as the only boring bar was almost the same size as the hole.
    Bored it out, bolt fitted, but once I parted off the flange the internal bore was a bit tight on the bolt, would be nice if I knew where I had stored the reamers I haven't used for thirty years but with a combination of using the drill and a scraper on the finished article - yay it fits.
    Was a bit worried it might be too tight in service, so found a gearbox to set up and test the operation of the crank, put the tighter bush on the bottom adjacent to the flange on the gearbox, put a smear of assembly lube that has Teflon in it and set the crank up on the gearbox, put the thin wave washer under the bolt head and tightened the bolt down with a 22mm spanner, until the step portion of the bolt nipped up, and tested the operation - smooth as silk.
    Very happy with the 2 hours work this afternoon, I am sure that Addo will be able to use the bushes in his project, if not the whole assembly
    I will try and attach photos of the crank in place on the bell housing of the gearbox.
    Bout time I got of my clacker and did some Fuego stuff!
    Ken
    Fuego 2.0 Clutch Pushrod Alignment-fuego-clutch-bellcrank.jpgFuego 2.0 Clutch Pushrod Alignment-fuego-clutch-bellcrank-insitu.jpg
    addo likes this.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    I'll take the bronze bushed pivot off the FrankenFuego and take some pics.
    addo and Kenfuego like this.
    Don't remind me!
    16,609
    Great to have seasoned input from several channels. I am having to treat everything from an initially empirical level; no Haynes, no factory data, no Pièces de Rechange guides.
    I almost want to try both the polymer bushes and oil-lites to see if one feels better than the other!
    Don't remind me!
    16,609
    Icon7
    Much better!
    The cable is badly stretched but setting it up with about 3/16" of free motion at the pedal plus liberal application of Nulon L80 to all pivot/wear points, has resulted in quite a smooth and light clutch. Amazing fix that would have been much harder without pooled information here. Many thanks to all.
    Kenfuego likes this.
