R12/15/17 Sway Bars
Results 1 to 12 of 12
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,351
    Default R12/15/17 Sway Bars
    Sorry to be spamming you lot like a keen honeymooner.
    Fulcrum "fulcrumsuspensions.com.au"
    ..are interested in quoting some larger sway bars for my R12.
    In order to quote they are just after some pictures of what the bars generally look like. To save me puling mine out does anyone have an image of the bars perchance?? :S
    Dec 2011
    Athens, Greece
    295
    I got an idea for you. Find out what the spring rates are for front and rear, then double them. This will be a good start. Drive the car, THEN see if you need thicker sway bars.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,960
    If you can wait till later in the week I will drag out my selection of R12/15/17 bars and take a few photos
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,960
    Regards Col
    1973 Alpine A110
    Jun 2004
    395
    I had a 25mm rear bar made for my 12 (I already had the 17G front bar) by Signature Swaybars in Nowra.
    They should have a master in stock now and it was about $250, but I had it made in the R12 "clamp in" style and not the R17G "bolt in" style.
    8,814
    You people are even more hopeless than I.
    INTERWEBS!!
    http://i34.servimg.com/u/f34/15/64/43/33/29032010.jpg
    ACHTUNG ALLES LOOKENPEEPERS
    Aug 2002
    3,351
    Perfect! Many thanks!
    And yes K-mac in Sydney have quoted $245 already. They have a template to work from it seems. Fulcrum do not. I'll let you know what they say.
    Dec 2010
    379
    If you're looking for an idea of the shape, the picture there shows 2 front bars. The rear shape is different and has 90 degree bends and instead of eyelets to bolt to drop links has holes horizontally through or just clamps on to trailing arms.
    Aug 2002
    3,351
    Ah! Shape is what they are after. I can see the shadow now on the top bar that mimics the bottom one. Opps.
    Aug 2002
    3,351
    Another reply from K-mac whom also quoted.. ($245 each end in case you missed it) they are't fond of this 26mm standard Gordini suspension idea..
    Hi Dan,
    At 26mm would be like driving a Go Kart no suspension!
    Recall Peter Brock track testing Commodore (with twice the arm leverage) anything over 27mm and just plough under-steered!
    Best regards,
    Kevin
    Someone in Sydney with a Gordini, go take him for a drive
    Dec 2010
    379
    Is standard gordini 26mm? I thought they were 24 on the front, and I can't remember but around 20 on the back?
    Aug 2002
    3,351
