Dynamat Advice
Results 1 to 25 of 25
Like Tree5Likes
  • 1 Post By geckoeng
  • 1 Post By DoubleChevron
  • 1 Post By David Cavanagh
  • 1 Post By Geoff Stewart
Thread: Dynamat Advice
    Fellow Frogger! G4ME's Avatar
    Feb 2003
    813
    Default Dynamat Advice
    Has anyone used Dynamat for sound and heat proofing in the engine bay?
    I'm looking at covering the firewall in Dynamat Extreme and then Hoodliner.
    It's a bit expensive so I'm just interested in people thoughts on the product or alternatives.
    Cheers...Paul
    There is a law against doing more than 100kmh...there's no law on how fast you get to 100kmh!!!
    Fellow Frogger! biologist's Avatar
    867
    I know someone who used it in their doors and engine bay, years ago now, (probably not the same standard of product? as these days) but they were very pleased with the insulation from road and engine noise which were their main issues.
    Biologist
    A
    one Megane Family
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,350
    My boot and front doors are full of it. But for very different reasons! For my purposes it works very nicely
    2017 Renault Koleos auto
    16,758
    I found body deadeners made the car transfer heat more quickly. You could always try insulation....
    EZ Cool Automotive Insulation heat barrier and noise reduction for cars, trucks, classic cars, street rods and much more
    I know some nutter that tried it and reckoned it was alright
    Dynamat would add a LOT of weight to the car if your using it for motor sport.
    seeya
    8,486
    Weight is always the killer, so I used neoprene with foil side on my firewall to great effect.
    It didn't handle the under bonnet use and the foil fell off, but it still insulates the bonnet without the foil.
    Have also done my bro's sprinter van roof with it, also to great effect and the same stuff has been used to insulate the internals of a a sliding door cavity.
    The lightness of the product makes it so easy to use, but of course there is bugger all mass there so not good for all applications like doof mobiles.
    Jo
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,777
    Hi Paul,
    I found Dynamat and Dynaliner very good for use in Graeme's Gordini. Dynamat on the floors as shown and Dynaliner 8mm in the roof. The car was a bit noisy from the back when we first got it running, and some 8mm Dynaliner on the back parcel shelf fixed that very well. I also did Dynamat on the inside of the fuel tank cover in front of the motor.
    Good source Dynamat Xtreme 9 Sheet Bulk Pack Sound Deadener | Motoquipe
    This is good as it is pre-glued, and really sticks. Glue application is always a problem, I feel.
    Dynamat Advice-insulation-back-sml.jpgDynamat Advice-insulation-front-sml.jpg
    Ray
    JohnW likes this.
    Ray geckoeng
    Think Old, But Run Modern !!
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,137
    seeya
    I know another. Ezi-cool gets my vote!
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's) Grandma's Taxi
    1974 D Special Manual Sedan ("Moby Dick") Weekend Warrior
    2015 C4 Grand Picasso ("Pablo") Workhorse & Grandpa's Taxi
    1982 2CV6 ("Gaston") Seasoned Traveller
    1975 GS Pallas ("GiSelle") Bonsai CX
    Simon's Avatar
    6,203
    My only thoughts would be to make sure there are no leaks into the car at the end of the exercise. I just think of the glue becoming unstuck, and water getting underneath. Likely more of a problem if the Dynamat is used on the floor like the bitumen mats originally used on many cars.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2003
    813
    Thanks guys. This is really helpful. I'm not too stressed about the weight as it wont be a competition car. I'm more worried if the Dauphine will carry my 100kgs up a hill than the sound/heat proofing firewall :-)
    Am I correct in assuming the original card for the firewall protection was just some sort of pressed card and not an asbestos based thing. Just had an awful thought after I'd removed the original.
    Cheers..Paul
    Fellow Frogger! laurie_lewis's Avatar
    Armidale, NSW
    234
    Paul, I thought dynomat said their product was not for use in the engine bay. Internal use.
    Feb 2003
    813
    seeya
    Hi Shane,
    I assume the nutter was you given the testimonial on the website?
    Given I only need a small piece for a Dauphine firewall have you got any left over you want to sell?
    Ballarat is heaps closer than Texas.
    Cheers...Paul
    16,758
    Quote Originally Posted by G4ME View Post
    Hi Shane,
    Cheers...Paul
    I'd go two layers. Yeah I might have a small amount here. I'll have to see how much is left on the roll that my father grabbed a while back.
    G4ME likes this.
    Fellow Frogger! thatguy's Avatar
    Oct 2012
    121
    I was looking at just this the other day and found car audio fraternities talking up Ping Jing as an alternative.
    They claim good results and the price is seemingly much better than Dynamat. Also widely available locally through eBay listings such as this one. There's different size packs listed at the bottom
    Ici.
    2,670
    i've got some left over if stuck how much do you need?
    1,137
    May be able to help Paul. Size of piece required would help. Cheers, Pottsy.
    Buvito Ergo Sum!
    The Fleet:
    Feb 2003
    813
    Quote Originally Posted by pottsy View Post
    Sweet. It's only for the firewall of the Dauphine resto. So Rough measurements are 1.2m x 0.7m.
    Cheers...Paul
    Feb 2003
    813
    Quote Originally Posted by thatguy View Post
    Interesting. That might be a good one for in the cabin. For the firewall I want something with some bulk (5 or 10mm) to replace the pressed card that is there already. good tip though and thanks.
    Paul
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    You guys are all getting old. I remember the days when it was the louder the better.
    Fordman likes this.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    Ici.
    2,670
    On a DS I stuck two layers on bay side and one on cabin side, aluminium cover over bay side and original vinyl on interior.
    16,758
    Quote Originally Posted by David Cavanagh View Post
    Bugger noise .... The stuff stops the massive heat soak dead in it's tracks.... It's worth its weight in gold
    Lasya likes this.
    16,758
    Cheers...Paul
    Let me know if Pottsy can't help. I should have that much here... Double it up though! It's weighs bugger all, but is very effective!
    1,137
    I reckon I should be able to spare enough for you Paul.
    Busy tomorrow but can maybe drop it over on Thursday.
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    Dec 2004
    VICTORIA
    83
    Default Dave was right!
    Dave did mention that age was a factor here! Back in January 2013 Paul asked about that card material on aussiefrogs and was advised that it would be caneite. Caneite was all the rage in the 50's and used in everything as a sound deadening material. So it was there to deaden sound rather than heat. You can breath easy Paul.
    cheers
    Geoff
    Nothing wrong with my memory!
    Cheers..Paul
    G4ME likes this.
    Feb 2003
    813
    Cheers, Pottsy
    Sounds great Pottsy and Thank you also to Shane.
    Where are you? I'm in Gisborne but my good friend Dave Cavanagh would also be a drop point.
    Cheers...Paul
    Feb 2003
    813
    A big Thank You to Pottsy. I have some firewall protection now.
    I love this stuff.
    Attachment 74811
