Renault 12 Flywheel
    Latrobe Tasmania
    16
    Default Renault 12 Flywheel
    Does anyone know whether or not the flywheel on the Renault 12 virage 1.4 is different to the 1.2 before I get a wrecker to grab one from his sole surviving wreck. ( He had 6 great cars crushed last week)
    Any info would be greatly appreciated!
    May 2002
    43
    Quote Originally Posted by fiveofour
    Yep, the bolt's (which hold it onto the shaft) of the 1.4 flywheel are placed in a larger diametre circle than those on the 1.2 (due to different shaft between 1.2 and 1.4?). I was going to swap flywheels between a 1.2 and 1.4 engine just the other day until I realised this!
    Sylvain
    Latrobe Tasmania
    16
    Thanx muchly!!!!
    Feb 2002
    Tamworth NSW
    496
    Thanx muchly!!!!
    Very true,
    And don't forget the clutch & pressure plate for a 1.4 is also different to the 1289cc.
    Kim.
    Latrobe Tasmania
    16
    Default Hi Kim
    You don't have a spare flywheel then in good nic?
    Stuart
    Ipswich, Queensland.
    1,880
    A 1.4 clutch can be fitted to a 12 flywheel given some machining. Basically the outside lump is removed, lightening it at the place where it needs it most, with some new tapped holes to fit the larger 1.4 clutch. I did it years ago on a few R12s to find the accelleration improved with no loss of uphil urge. This was done to standard and modded cars.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
