Rear wheel bearings - Scenic/Clio?
    Jun 2011
    Tecoma, VIC
    101
    Default Rear wheel bearings - Scenic/Clio?
    Anyone able to kindly point me at the rear wheel bearing sizes for a Phase 1 Scenic (2WD about 2003)?
    I believe they are the same on a number of Scenic/Clio/Megane variants.
    I have to replace the rear discs so will do the bearings at the same time (as I believe that is suggested as 'a good idea').
    Ta in advance.
    Brisbane/Australia
    2,205
    It's not only a good idea to replace the rear bearings when doing the discs but you've got no choice anyway because the disc/hub and bearing are a sealed assembly and can only be replaced together.
    Don't know about the Clio.
    There are two sizes for the JA Scenic and you'll probably have to quote your VIN number to ensure you get the correct size.
    Are you looking to buy aftermarket or genuine Renault?
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Yep, as above they're a combined assembly. Its a bit annoying as it makes the disc replacement expensive and at the rate they wear the bearing are usually perfectly ok...
    Just did mine, Carrevelle supplied SKF branded ones for about $120-140 a pop I think. Front discs were well under $100 for the pair...
    This is also useful http://www.ebay.com.au/itm/Quality-B...item25950c5994
    Jun 2011
    Tecoma, VIC
    101
    Thanks, I think I'll just order the bits from someone that knows for sure which bits to supply
    May 2002
    canberra...
    8,876
    Quote Originally Posted by StephenH View Post
    That would be Carrevelle. Get in there before Ken leaves and all that off the top of his head knowledge goes with him... We'll all be back to having to supply VIN numbers to get a bloody oil filter..
