K4M into an R10 - Page 4
Page 4 of 4 First 1234
Results 76 to 99 of 99
Like Tree21Likes
Thread: K4M into an R10
  1. #76
    Oct 2012
    599
    Is anyone familiar with the 1.4 R18?
    This starter has come up
    https://www.ebay.com.au/itm/CLEARANC...4383.l4275.c10
    It mentions 847, which is what my current flywheel is from but looks like the solenoid is in a different spot, may not be an issue. There is no mention of the nose length which is the important number missing.
  2. #77
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,179
    Does the 8/10 have a grommet at the back for a starter crank?
    Suppose cranking a high comp modern engine by hand would probably suck.
    You are just trying to find a "reno-esk" starter motor with an appropriate shaft to engage the flywheel at the moment? I mean mounting is/isn't an issue it's just the shaft length now?
  3. #78
    4,242
    Yes, you can crank R8/10’s by hand, but it relies on having a drive dog bolt on the crank pulley that Christian is unlikely to use on his.
    The R12 has a std hex head bolt on the pulley hence I can only crank one of my cars - not that I’d like to try to crank start the engine out of my old R10.
    KB
  4. #79
    Oct 2012
    599
    I've welded up the hole on the body for the hand crank, so no hand cranking for me.
    May also be close to impossible to hand crack a modern engine.
    Sent from my Nexus 6P using aussiefrogs mobile app
  5. #80
    Aug 2002
    3,179
    ..wasn't really suggesting one hand cranks a modern 16v donk But it would have added just that touch of originality.
  6. #81
    Oct 2014
    Windsor 2756 NSW Australia
    505
    Although I certainly don't try to hand crank start any of my Renault collection, I use the hole in the body to give easy access to the crank when I need to line up TDC.
  7. #82
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,754
    I would say that the R18 1.4 (1397cc) would be much the same as a Renault Virage (late R12) which sold here in the late 70's
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  8. #83
    Oct 2012
    599
    Took a gamble as it was only $100 including freight.
    Had to shave one corner of the flange. It also looks like the main housing has been machined on one side for clearance, the wrong side bit this probably means I can shave it down a little as I think it's still interfering with the block but not by much.
    The nose is slightly shorter but my quick measurements say it'll still engage.
    renault8&10, COL and bowie like this.
  9. #84
    4,242
    I picked up a complete EL column today with wheel, shrouds etc.
    The rag joint coupler I had bought from Dapto was too big.
    Do you recall if the donor vehicle for yours looked like this?
    Attached Thumbnails Attached Thumbnails K4M into an R10-f7a86afb-1520-43e6-a9aa-7c894244a824.jpeg
    KB
  10. #85
    Oct 2012
    599
    Which part is the wrong size, the spline or the flange?
    I can't recall exactly what mine came from as I ended up with so many of them looking for one that fitted. Is it possible to drill the one you have to fit the Renault rag joint? I had also considered making a plate to adapt between different pitches but there isn't much space to fit it in.
    All I remember is it came from a ute and it was the end that connected to a joint at the steering box.
  11. #86
    4,242
    Yeah, too big on the splines. The Dapto one sounds like it came from the same location between the column and steering box. I think it was a D21. The flange spacing is perfect, but the spline diameter too big. Up until today, I didn’t have the bottom part of the falcon shaft to compare it to.
    The blue Ute pictured is at picknpayless Blacktown and an early D22, so I’ll go down there and take a look.
    KB
  12. #87
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,754
    Hi Christian
    At this stage in proceedings I would be hooking up a battery and testing out the starter motor to make sure it all engages nicely. You could possibly check engagement with some bearing blue or using a permanent marker on the pinion.
    Regards Col
    1973 Alpine A110
  13. #88
    Aug 2002
    3,179
    Yes this is getting exciting!
  14. #89
    Oct 2012
    599
    Hi Christian
    That is my plan but I'll need to take the head off as there is no timing belt on the motor.
    That bell housing has a chunk of the oil seal suround missing so I'm willing to cut the starter cover to I can see how much engagement I have.
  15. #90
    Member Johan's Avatar
    Hamilton, New Zealand
    40
    Love how everybody gets involved with heaps of knowledge when a fellow Frogger has a problem.
    This must be one of the best sites on the net!
    LeMansTragic, J-man and JohnW like this.
    1965 Renault R8 :
    2003 Citroen C5 v6
    I don't have a bucket list,
    but my fxxket list is a mile long
  16. #91
    Oct 2012
    599
    I decided to take the cam shafts out so I could test the starter engagement, it's got to come apart anyway.
    Good news, the starter engages. It is engaging 9mm of the starter pinion, there is a leader on the teeth so it's not getting complete depth on the whole tooth of the ring gear.
    I could machine a mm or two of the starters mount face but not sure it's worth it. There is only 3 mm of clearance in the idle position so I think I'll be leaving it alone. It's close as it is.
    This opens up the possibility of putting a timing gear on the back of the flywheel. There is about 10mm of clearance so I can get the gear cut from 6mm plate and bolt or weld it to the flywheel, then get it rebalanced.
    bowie likes this.
  17. #92
    Oct 2012
    599
    Couldn't help myself. They are larger then I wanted but the price was right, paid $70 including shipping. They are from a 2006 GSXR 600 so they are 40mm.
    I've already removed the secondary butterflies as I won't need them. I won't use the up stream injectors either so I'll plug those holes when the time comes.
    It may not add much performance but it will sound awesome.
    Sent from my Nexus 6P using Tapatalk
    bowie, ReidarUF and J-man like this.
  18. #93
    Aug 2002
    3,179
    Price is right!
    Proven fun times you are going to have.
    What sort of length inlet runner do you think you will end up with?
  19. #94
    Oct 2012
    599
    Price is right!
    No idea what length yet. I may make the manifold neck in a little in the middle to compensate for the larger throttle plates. There are lots of factors.
    With ITBs the length of the runner is from the mouth of the velocity stack to the valve, position of the throttle along the runner doesn't make much difference. It will make a difference for the injectors though, not sure how much.
    I'll make it so I can put the upstream injectors back in just in case one day I'm feeling crazy. Not sure I'll ever get time for that though.
  20. #95
    Aug 2002
    3,179
    Ah interesting the position of the throttle plate doesn't make to much of a difference. I assumed that's where all measuments started.
    $70 bucks. Man. Good stuff.
  21. #96
    Oct 2013
    Redlands
    6
    I think youd be surprised what difference they make. In the uk bike throttle bodies are a huge thing, with some awesome results. I had a set of R1 bodies on a Clio 172 motor running on standard management and it was a whole different car. It had a map tweek and saw a jump from factory stated 172 bhp to proven and safe 200. If nothing else Im 100% with you on the noise, Id have them for that alone even if I lost power....
    J-man likes this.
  22. #97
    Oct 2012
    599
    Flywheel sorted, R5A sourced by Ray. Only issue is that is has a symmetric trigger pattern so it will indicate TDC and BDC with no way to tell them apart. The K4M flywheel only indicates TDC. This isn't an issue in the R5 as it isn't injected and doesn't have sequential ignition.
    The solution in a cam angle sensor, bad news is the K4M I have doesn't have one, it's from a Clio II, not sure if then engines from a Clio III have the sensor, its in the top of the head and must have a matching part on the intake cam shaft, which mine also does not seem to have.
    To get around these short comings I either have to get a head and cam shafts with the sensor which I'm not sure was in any Australian cars? Perhaps someone may know this. Or put a cam angle sensor on the end of the camshaft. The distributor from an E6J fits with an appropriate spacer, that would give me the part that engages with the end of the cam shaft. Was the Clio I ever imported? If not and I end up going down this path its not a heavy part to import. Or I can just make one. Then I can use the cam sensor off just about anything.
  23. #98
    Aug 2002
    3,179
    Is there a crank pulley at the front.. er back you can add a trigger wheel onto? Maybe sneek it in behind the existing harmonic balancer?
    Assuming it just has to drive the water pump and alternator, Google images suggest it would be pretty straight forward to space out?
  24. #99
    Oct 2012
    599
    I can space the front out as the crank is keyed even though the timing pulley isn't. You still need to have a cam angle sensor to do sequential ignition. You can do obviously run without it as that is how the engine is set up normally. You get better timing accuracy with the cam sensor as it takes care of any timing chain/belt jitter.
    I'm thinking the vvt version of the motor is the one with a cam sensor and a slightly different intake cam shaft.
    From my initial research I'm thinking I can graft on the CAS from a Nissan engine like an RBxx, SR20 or a Mitsubishi 4g63 (the go fast version). I'd be putting it on the back of the motor where there is a rubber plug covering up the end of the camshaft.
    bowie likes this.
