Renault 15 Rear End Traing Arms
Results 1 to 10 of 10
    266
    Default Renault 15 Rear End Traing Arms
    Hi
    I understand that you don't simply replace the bushes on the Renault 15 rear trailing arms but actually replace the trailing arms themselves?
    Would anyone know where I can get these rear trailing arms from?
    Regards
    Alan
    1000+ Posts driven's Avatar
    Apr 2005
    1,407
    I used two adjustable rod ends, better than original
    See Pic
    Attachment 72373
    Dec 2010
    379
    They look good, do they twist like the originals do though? To allow for body roll?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,960
    See Pic
    Attachment 72373
    Where did you purchase these from Driven?
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    266
    Driven
    Thanks for your reply.
    What Brand and Part No. are they?
    Looking at the Service Manual last night, doesn't the rear roll bar bolt onto the rear trailing arms?
    I'd like to know where you got them from too.
    Regards
    Alan
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,960
    Quote Originally Posted by 120L View Post
    Driven
    Regards
    Alan
    Yes the rear anti-roll bar does bolt to the trailing arms, so if you used these you would need to fabricate a bracket. but would be interesting to see what Driven did when he installed the trailing arms.
    Regards Col
    1973 Alpine A110
    Apr 2005
    1,407
    Hi Guys,
    I bought my parts from Linear Bearings
    http://www.linearbearings.com.au/wp-...-Brochure-.pdf
    The speed shops charge way too much
    You need to work out dimensions as I did this 12 years ago. I have no pics unfortunately.
    I was just copying what V8 super cars were doing
    I fabricated a bracket for the antiroll bar. This was secured on the rod end threads by extra nuts
    This gives you some backwards/forwards adjustment as well
    I drilled holes in the bracket and plug welded studs at the right points.
    Need to offset the barrel as well to fit in the roll bar.
    Some roll bars have holes for mounting, the heavier ones.
    Lighter ones have brackets for attaching the round bar.
    As the rod ends are narrower than the original part, spacers will do the trick
    See pic with spacers to offset and sketch of bracket I made
    Attachment 72397
    Attachment 72398
    Mar 2015
    Geelong Australia
    67
    Sweet design but not sure how you would comply with engineering requirements for roadworthyness . Is the car registered ? I used to flaunt the rules a little too . I couldn,t afford a custom heavier sway bar for a R17 some time back so made mountings to run two R12 units , one in the standard position and one running backward , forming a square . worked well , nice oversteer !!!!! Another trick I did was to run renault 18 rear shockers in a 17 . A bit long from memory but a lot firmer and cheap .
    266
    Driven and Toolman
    Many thanks.
    Toolman, would you have the brand and part number for the trailing arms you bought?
    Size, diamter, length?
    Regards
    Alan
    Apr 2005
    1,407
    PS Paint them all matt black and it then looks like original
    They don't even know what a R15 is anyway.
