R10 Question on Carbies
Results 1 to 7 of 7
  • 1 Post By JohnW
Thread: R10 Question on Carbies
    Mar 2011
    Roselands
    250
    Default R10 Question on Carbies
    Would a R10S twin Webber caby and manifold, fit on standard R10?
    Thanks for your input,
    Roger
    4,363
    You mean a twin throat 10S weber?
    yes, it will fit. I used to run one. Arguably the best performance would be gained with a better cam though.
    A lot of people used to fit that carb on an 8 port early R8 head to the R10 block back in the day.
    KB
    Boonah Qld
    2,506
    Just to be clear. The manifold won't fit a standard R10 head. It is for an 8 port head where as the R10 head has 6 ports. Early R8's and Floride S and R10S had 8 port heads.
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    472
    I have successfully used an inlet manifold off a 8 port head on a 6 port head with no problems. What you need to be aware of is the different thickness of the flange. In some cases, you may need to reduce the thickness (only where the nuts go on) to enable the nuts to pull up both manifolds securely against the head.
    Henry
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
    Perth Western Australia
    2,672
    Call me Mr Thicky but...Inlet manifolds 8 port to 6 port?
    Have you got any pictures??
    472
    The inlet ports on 8 port and 6 port heads are in the same position. It's just that on the 8 port there is a bit of aluminium separating each pair of ports. Even the gaskets are interchangeable .
    Henry
    10,705
    Quote Originally Posted by rubyalpine View Post
    Henry
    Which always leads to the question: why did they do it? Start with 8-port, revert to 6-port and then offer 8-port for the performance model, that is. Why the 6-port??? Cheaper to make perhaps?
    Anyway, the thread's question has been answered. I should dig out that 956 8-port head that is wrapped up carefully in the garage.... They'd be getting rare now.
    jaahn likes this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
