Rather late than never
Results 1 to 19 of 19
Like Tree4Likes
  • 1 Post By Kim Luck
  • 2 Post By driven
  • 1 Post By renault8&10
Thread: Rather late than never
    Member Johan's Avatar
    Hamilton, New Zealand
    40
    Default Rather late than never
    Not to long ago someone asked about Powder coating wheels for his Renault.
    I am not a fan of powder coating.
    See attached photos as to why.
    1965 Renault R8 :
    2003 Citroen C5 v6
    I don't have a bucket list,
    but my fxxket list is a mile long
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    472
    That's not good. It reminds me of the time I put that goo into my tyres that's supposed to automatically seal punctures.
    It ate through the paint, and then ate through the steel rims!
    Henry
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
    1000+ Posts Frans's Avatar
    Auckland
    1,477
    All it needs is a chip then it will rust away on the inside while it looks beautiful on the outside. Eike's G in RSA were prepared for a show many years ago and all his wishbones and other suspension parts were powder coated. Not good! But then only in hindsight because we didn't know better then.
    Frans.
    Old enough to know better
    Young enough to do it anyway.
    10,703
    Quote Originally Posted by Johan View Post
ID:	68524Click image for larger version.
    Our steel security doors are powder coated and look even worse. Total failure of whatever preparation coat they used.
    Better to use a paint brush and decent paint!!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,779
    Funnily enough preparation is the key to the success of all forms of coating.....
    JohnW likes this.
    St Helens Tasie
    598
    Agree with Kim. Powder coating ,when prepared correctly is very good. If the metal is degreased, etched in phosphoric acid and not touched by any grease bearing substance even human hands, the powder will coat and provide a very durable surface.
    Auckland
    1,477
    And then you tighten the wheelnuts and crack the powder coating and the oxidisation process starts.
    It will be good for certain applications only. Not where chips or any likely things can happen. The major drawback is that the coating looks perfect while the rust has travelled several millimeters or inches underneath the coating, and you don't know about it.
    Frans
    Melbourne, Aus.
    17,779
    I'd suggest that steel wheel is from the 1970's, so it's now 40 plus years old, and like anything else that has been obviously so well cared for, it probably needs a clean up and re-coat.
    Banned
    sydney, australia
    11,301
    i enquired about having some aluminium wheels powder coated, and the guy said pretty much what Frans said. he recommended that it was not a suitable coating for car wheels.
    Melbourne, Aus.
    17,779
    Looking at the photos again, I'm not even sure it is a powder coated wheel! Just looks like a poorly painted one. Then again, I could be wrong, as the company that makes them is still in business and still powder coats their steel wheels and I seem to remember seeing them on countless 4x4's, not just Renaults!
    http://www.roh.com.au/trak2-series-trak2-white.php
    Fellow Frogger! G4ME's Avatar
    Feb 2003
    796
    I just had a set of rims powder coated. They look unreal and if they last 30 years I probably wont care that much.
    There is a law against doing more than 100kmh...there's no law on how fast you get to 100kmh!!!
    Sep 2004
    Tamworth UK
    618
    Those rims are at least 70s, if not very early 70s. I should know, I owned them before Johan, and before me by more than one step they belonged to an R8 called Daktari, raced, rallied etc by Mike Marshall.However, I would still be very cautious about where the nuts seat, with any coating including paint! Powder coat technology has moved on a lot in 45 years!
    Kim, these wheels were made in NZ by Jolly Wide Wheels, not the company you quoted.
    1000+ Posts driven's Avatar
    Apr 2005
    1,405
    Also looks like the rims were run with tubes rather than tubeless.
    Dakar raced, rallied...salt pans perhaps??
    Looks like salt water penetration through to inside of rim through valve area.
    As air is available corrosion will continue
    Lesson here anyone running tube tyres should check internal rim corrosion
    Split rim 4WD also applies here
    Wildebeest and JohnW like this.
    Sep 2004
    Tamworth UK
    618
    Don't really think that NZ has too many salt pans, and a very long way to Dakar
    Yes they had tubes, as did most "rally" tyres back then. I would be surprised about salt water too. Just a long time stored in a barn.
    Don't remind me!
    16,609
    I may be wrong, but the modern alloy wheels fitted to PSA cars appear to be powder coated on the backs - it seems to endure quite well away from harsh environments.
    Feb 2001
    Romsey, Victoria, Australia
    4,804
    I've been going through rims out in the back yard and founds lots of 12 special rims (1 was a G) and scrapped most of them because there to rusty to use and non of them had been power coated.
    Fact of life I think......Steel rusts.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    4,363
    Quote Originally Posted by kiwia110 View Post
    Were made - past tense? it looks like that company ceased trading in 2002?
    Kim Luck likes this.
    KB
    Sep 2004
    Tamworth UK
    618
    Yes. They were made in the 70s.
    Melbourne, Aus.
    17,779
    The ROH wheels are still made in Oz. Either that or they were ahead of their time in having a web site back in the 70s! ��
