Dauphine Rear Wheel Bearings
Results 1 to 2 of 2
    Jan 2013
    Geelong
    515
    Default Dauphine Rear Wheel Bearings
    Dauphine Rear Wheel Bearings-img_0737.jpgDauphine Rear Wheel Bearings-img_0738.jpgDauphine Rear Wheel Bearings-img_0739.jpgDauphine Rear Wheel Bearings-img_0740.jpgDauphine Rear Wheel Bearings-img_0741.jpg
    I decided to replace the rear wheel bearings.
    Just as well! One side had the seal spring wrapped around the axle & is missing half its balls!
    I use a Litchfield puller left over from VW days and while the better bearing came out easily, the bad one didn't budge. Instead the axle went back into the transmission!
    What's going on? Is this a sneaky Gallic booby trap? Every other axle I've worked on is bedded into the planetary gears on the diff & can only go in so far till it stops.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Jan 2013
    Geelong
    515
    Default All good!
    The axle this side was much looser & had drifted out.
    I just tapped it back gently with a plastic mallet to see how far it would go & it eventually bedded in after which the puller worked.
    And there were no balls missing but the non-metallic cage supporting them had disintegrated.
    1949 Citroen Big 6
    1955 MGA1500
