Dauphine Rear Shocks
Results 1 to 8 of 8
  • 1 Post By jaahn
Thread: Dauphine Rear Shocks
    Jan 2013
    Geelong
    514
    Default Dauphine Rear Shocks
    The manual test procedure is to pump up & down checking for even resistance to movement.
    My rears pass that test and the rubbers are perfect, BUT, the compression resistance ( hitting a bump) is considerably less than the expansion resistance (falling in a hole).
    Is this normal?
    Are they single action?- they resist falling into a hole but less resistance to bumps because of the Aerostable units??
    I'd hate to spend 100+ euros on a new pair to find they act just like the old ones!
    BTW, they are blue.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Newcastle
    2,621
    Hi geodon
    The rear shocks on swing axle cars were always made biased in their action like that. Not single acting really but considerably more resistance on extension than compression.
    This was used to help offset the tendency for the wheels to "tuck under" when cornering. That is the reason why you should not use random shocks off other cars.
    cheers jaahn
    Sunroof likes this.
    10,786
    Hi geodon
    cheers jaahn
    Thanks for the education Jaahn, I'd not thought of that.
    It is obvious once you think that way for a microsecond - did Dauphines have the limiting straps?
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    10,786
    You'd want even-ness of course, but it is hardly a dynamic test. My front Konis were smooth as silk (and 40 years old) but the ride improved noticeably with new ones. Ditto the rears, when I replaced perfectly smooth standard shockers with new Konis.
    Renault 4CV 1951
    Renault R8 1965
    Jan 2013
    Geelong
    514
    The distributor doesn't have shocks for the Dauphine Gordini but has some for the R8. Details: Dauphine vs (R8)
    Rears:
    Fully open 364mm (361)
    Fully closed 232 (243
    Fronts are similar.
    FO 313 (294)
    FC 212 (206)
    Ergo, interchangeable?
    1949 Citroen Big 6
    1955 MGA1500
    10,786
    Quote Originally Posted by geodon View Post
    Rears:
    Fronts are similar.
    FO 313 (294)
    FC 212 (206)
    Hmm. Different weight car and different spring rates. I don't know how they compare but I wouldn't go there myself. There are two different lengths for R8 front shock absorbers too.
    Renault 4CV 1951
    Renault R8 1965
    Ipswich, Queensland.
    1,898
    I don't know what the damping differences are between the aerostable and the standard Dauphine, but I will be buying a set of the Record brand Aerostable type for the rear of my wife's '62 Dauphine Gordini this week from Melun Retro, as the original ones are leaking. They seem to work OK using the bounce test, but chances are they are not controlling the spring very well whilst on the road.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    Ď02 and Ď03 Renault Clios 1.4L
    10,786
    I suspect you'll find quite an improvement Alan. Be interested to hear in the fullness of time.
    Renault 4CV 1951
    Renault R8 1965
