Dauphine Brake Shoes
Results 1 to 9 of 9
    Jan 2013
    Geelong
    514
    Default Dauphine Brake Shoes
    The workshop manual is explicit: the long shoes face the front.
    However, the rears on mine are t'other way around on ONE side. Incorrect assembly??
    Pictured is the correct way, yes??
    What a challenge removing that top brake spring is!
    I spent over half a day welding bits onto some derelict multi-grips & then realized it only works only on one side plus it would have damaged the new linings during re-installation later.
    I found used Hazet brake spring pliers online & they are on the way. Top quality albeit at a price. The prices paid for those Hazet toolkits that fit inside the VW beetle spare wheel would make your jaw drop.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,663
    Geodon,
    As your project is of interest to a lot on here, why not transplant it all to one thread on the Project folder. I am sure it would be far better to be able to go through the whole project in one place.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Jan 2013
    Geelong
    514
    Yes Ray.
    I was thinking that.
    I will open the project folder & link the existing posts.
    1949 Citroen Big 6
    1955 MGA1500
    1000+ Posts driven's Avatar
    Apr 2005
    1,433
    Get one of these for spring removal
    Cheap
    Attachment 63595
    Autobarn, Supercheap
    Jan 2013
    Geelong
    514
    Saw that & yes it was MUCH cheaper,
    But the pointy bit would dig into the lining on re-assembly?
    Instead of a point, the Hazet has a flexible foot to spread the load with a roughened surface to get grip & prevent slippage.
    1949 Citroen Big 6
    1955 MGA1500
    Simon's Avatar
    6,172
    Quote Originally Posted by geodon View Post
    There was a Renault special tool that clipped onto the brake shoe at the bottom, with a bend at the same level of the spring for the point bit of the pliers to hook into so as to not damage the lining.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    10,786
ID:	63586Click image for larger version.
    Photo 1 does look right. Photo 2 is hard to see.
    Regarding the spring removal/replacement tools, damaging a tiny part of the lining area really doesn't matter IMHO. Those tools were designed when linings were riveted on, before the ultra-modern "bonded" linings appeared. The tool pin pressed against a rivet head.
    I used one like the Super Cheap example when I put Dauphine brakes on the 4CV a couple of years ago and it was fine. Always a bit tricky if you haven't done it before and graduated in high level swearing.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Jan 2013
    Geelong
    514
    Default The Hazet Pliers!
    Man! What a difference the right tool makes!
    Much dearer than the ones above but the grip on the shoe is foolproof.
    1949 Citroen Big 6
    1955 MGA1500
    10,786
ID:	63762Click image for larger version.
    That's wonderful. I might have to find one of that exact tool. Many thanks for posting.
    Renault 4CV 1951
    Renault R8 1965
