Dauphine Wheel Studs
Results 1 to 21 of 21
  • 1 Post By JohnW
Thread: Dauphine Wheel Studs
    Jan 2013
    Geelong
    511
    Default Dauphine Wheel Studs
    I need to clean up a few.
    Can someone confirm these are M12 1.25?
    It's nice to be back in Metric Land.
    I wanted to clean up my Land Rover studs, measured them to be half inch UNF 20 & after I ruined one I found they were half inch BSF! It was quite common to have UNF, BSW & BSF on one component eg gearbox.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Quote Originally Posted by geodon View Post
    That is the size for all the 3 stud cars.
    I cleaned mine up on a wire wheel. Are your threads damaged?
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jan 2013
    Geelong
    511
    No, Col, not damaged, just a bit "crusty".
    1949 Citroen Big 6
    1955 MGA1500
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Wire wheel brings them up great.
    Regards Col
    1973 Alpine A110
    Newcastle
    2,592
    Hi geodon,
    Well a LR was made in GREAT Britain. So it follows that it would be a collection of all things from the Empire
    The sum total of all that is a load of ****.
    Sorry for the dig At least the French settled on metric and kept to it.
    Jaahn
    Jan 2013
    Geelong
    511
    Yeah but a die nut is safer.
    I only have a 100mm angle grinder but it has inflicted countless injuries upon me so the less I use it the better!
    1949 Citroen Big 6
    1955 MGA1500
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    I made this up a few years back out of and old washing machine motor
    You can also buy something like this from various green sheds around Australia for your battery drill.
    Not quite as viscous as an angle grinder.
    Regards Col
    1973 Alpine A110
    10,754
    That's neat and simple. Good of you to take off the safety guards for the photo
    jaahn likes this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Guards what are they??
    I did think about making a cover for the motor but just have not got around to it yet.
    Regards Col
    1973 Alpine A110
    10,754
    I wouldn't be worried about the motor... Just the brush. Those simple electric motors are great for home made things, like the fan above my workbench.
    Renault 4CV 1951
    Renault R8 1965
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Although a guard on the brush would take some of its usefulness away.
    I wear eye protection when using it.
    Regards Col
    1973 Alpine A110
    Jan 2013
    Geelong
    511
    Col, because the units I made for MG Midgets don't work on the Dauphine, I'm thinking of using The Redneck Method of Coil Spring Compression viz. a large number of cable ties.
    Would you approve?
    In the name of safety, afterwards I will cut them with VERY long handled secateurs.
    1949 Citroen Big 6
    1955 MGA1500
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Would you approve?
    What units are these?
    Regards Col
    1973 Alpine A110
    Jan 2013
    Geelong
    511
    I made coil spring compressors when we had 3 Midgets in the family but they slip a bit. I will have to re-think the design & try again. Watch this space!
    I was just testing your "devil-may-care" outlook re safety guards to see if extended risky business in the suspension department
    1949 Citroen Big 6
    1955 MGA1500
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    I see now.
    Its only as risky as you want to make it. These brushes are designed to be used in a drill and there is no guarding there.
    Any spring compressor can slip and let the stored energy escape, make sure all your body parts are out of the line of fire.
    Regards Col
    1973 Alpine A110
    4,366
    With the shock absorber removed on an R8/10, I use two stainless plates (`4mm thick) with two holes drilled; and two threaded rods with double nuts top and bottom as a homemade spring compressor. The plates go through the spring coils (hence the shock removed) and wind together to compress the coils. The plates are obviously long enough to go through the spring with enough left over space for the threaded rods to be external to the spring.
    And Geodon, COL has experienced R12 coil springs, nothing can scare him!
    KB
    It's how I roll...Brisbane
    33,032
    I have replaced the front springs on my Floride just by using a trolley jack, it can be done
    4,366
    Quote Originally Posted by 59 Floride View Post
    I have too, but the trouble is getting them back in. The spring has to sit astride the little ridge on the spring seat which is hard to do on an R8/10 with a trolley jack. Are the dauphines and florides different there?
    KB
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Now that we have completed the OH&S stuff and have guards on our wire wheel brushes and non slip hooks on our spring compressors.
    Back to the original thread topic of how is the wheel stud cleaning going? and which method have you decided?
    Regards Col
    1973 Alpine A110
    4,366
    back on topic! you obviously haven't been around here long COL?
    KB
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Regards Col
    1973 Alpine A110
