My New Project
Results 1 to 14 of 14
Thread: My New Project
    Apr 2011
    Melbourne, Australia
    175
    Default My New Project
    Hi,
    I have obtained a late 1955, early 1956 Renault 4CV from a friend. Unfortunately it has spent many years out in the elements, so it is definitely going to be a "Labour of Love" to get it back on the road.
    Does any one have plans for a rotisserie for either a 4CV or an 8 or 10 that could be adapted?
    Regards
    DavidMy New Project-pb010764.jpgMy New Project-pb010765.jpgMy New Project-pb040767.jpgMy New Project-pb040770.jpgMy New Project-pb040771.jpg
    10,797
    I hope there's no inside-out rust along the roof line gutter spot welding.... If there is, best of luck. It looks a bit tired and moth-eaten from the photos.
    Note it has the rare bottom-hinged glove box lid - they can be expensive to buy and are hard to find in my experience. Off things like that can make the worst shell worth picking up, or at least I reckon so.
    Good to see yet another emerging. You can hide the hole in that rear bumper at the front with the number plate!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    4,378
    I can take some pics of my stand and give basic dimensions but it is not a true rotisserie as it doesn't have a ratchet mechanism to rotate the shell 90deg. It uses the bumper mount points to mount the shell so your width and depth etc will be governed by those dimensions on your shell.
    Attached Thumbnails Attached Thumbnails My New Project-dscn2270.jpg   My New Project-dscn2266.jpg   My New Project-dscn2349.jpg   My New Project-dscn2269.jpg
    KB
    Fellow Frogger! G4ME's Avatar
    Feb 2003
    810
    Quote Originally Posted by DJ 750 View Post
    Hi,
    Regards
    DavidClick image for larger version.
ID:	62992Click image for larger version.
ID:	62993Click image for larger version.
ID:	62994Click image for larger version.
ID:	62995Click image for larger version.
    Try JY Dog on here with a PM. He leant me a home made rotisserie that I used for the Dauphine. He was trying to sell/give it away about 3 months ago before moving house. It may still be around if he is still on Aussiefrogs.
    Good luck...Paul
    There is a law against doing more than 100kmh...there's no law on how fast you get to 100kmh!!!
    Boonah Qld
    2,536
    Once saw one made from two engine stands. The bumper bar attachments were welded up with a piece of 75mm? pipe that was put into the swivel point. New ones cost about $1400 to $1500 last time I looked. But have a hydraulic device for altering height.
    Boonah Qld
    2,536
    By the way love the car. Having great fun with my restoration. Although a bit slow as other things get in the way. Hope yours goes well with out too many nasties.
    4,378
    The mini guys often use two engine stands, but they can run a single pipe mounted to the bulkhead, then runs through the speedo hole to the back and through a removable panel on the rear seat out to the second stand.
    The engine stands are often tilted back however.
    KB
    Jan 2013
    Geelong
    514
    Icon9
    [QUOTE=Sunroof;1303391]Once saw one made from two engine stands. The bumper bar attachments were welded up with a piece of 75mm? pipe that was put into the swivel point. New ones cost about $1400 to $1500 last time I looked. But have a hydraulic device for altering height.[/QUOTE
    Sunroof, market forces are your friend:
    Tomahawk USA Auto CAR Body Rotisserie Twirler Restoration Hoist Lift Jack | eBay
    Mind you, there are real rotisseries and El-Cheapo knock offs:
    https://www.youtube.com/watch?v=yNWwt3wRW0U
    Buuuuuuuutt, with a Kerb weight of around 600kg wet, our requirements are modest compared to an F250 ne c'est pas?
    I made one for doing split screen Kombis before they became popular & available. It cost me $1500 for the steel! I sold it when I cleared my sheds.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,149
    Cool! So will we see a 4CV restoration thread then? That grille bar on the front is pretty rare. I haven't seen the choke on the floor by the gear shift and the pull starter behind the hand brake for a while. It looks earlier than 55-56 to me with that dash and pull starter
    Like John said, I hope it doesn't turn out to be too rusty; it'd be great to see another one restored
    cheers,
    John
    Simon's Avatar
    6,174
    Quote Originally Posted by J-man View Post
    Based on the oval plate, and the features such as the dash and front badge surround, DJ would be spot on with his dates. I'm hoping it will be an easy resto too!
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Apr 2011
    175
    Hi,
    Thanks for all the information about rotisseries. The more I work on the car (or try to loosen rusted on bolts), it is going to be a long slow and I am sure painful restoration.
    David
    Feb 2001
    Romsey, Victoria, Australia
    4,839
    I was going to ask about that but I was thinking that with my family background I should know the answer already. Did someone fit a rear bumper on the front or is it the typical Renault tightarse tradition of making one part fit all and just cover it with the number plate?
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Feb 2001
    4,839
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    10,797
    Quote Originally Posted by David Cavanagh View Post
    Cheaper not to make the hole I'd have thought. No, just that someone damaged the front one and had an undamaged rear and they are the same size. My 4CV is just the same.
    Renault 4CV 1951
    Renault R8 1965
