Warning - aftermarket fuel pumps for R8/R10 engines
Like Tree4Likes
  • 4 Post By JohnW
Thread: Warning - aftermarket fuel pumps for R8/R10 engines
    10,754
    Default Warning - aftermarket fuel pumps for R8/R10 engines
    Well, I've been praising my new fuel pump "avec levier" for a few years now. It is the perfect solution for a car used intermittently (unless you go electric), as you can hand prime the carburettor rather than cranking the engine enough to pump up the fuel. So far so good and the pump works perfectly after quite a few years and I'd guess 25,000 km.
    Now the warning. I fitted new plugs to the R8 today and noticed a bit of discolouration on the top of the pump as I cast my eye carefully over a familiar friend. Ah..... What I found was exactly the same as the pressed-in brass fuel line fitting on Solex carburettors. Just like the "Solex problem" it was leaking, the slight amount of fuel on the top of the pump had attracted dust and the fitting pulled out completely just by hand. It wasn't partly out, fortunately. This outlet faces upwards!! So, had it come out when running, the pump would have sprayed fuel everywhere, and upwards.
    I've reverted to my old solution for the 4CV and knurled the brass tube by rolling a narrow file diagonally across it and glued it back in. Alan Moore made a suggestion a while back about a suitable glue if I recall correctly.
    So, please don't forget the other end of the fuel line, that at the fuel pump outlet!
    Please go and check.....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Fellow Frogger! potentz's Avatar
    Jul 2011
    adelaide australia
    308
    ive had this happen on a r10 pump!!!just exited a fast right hand hairpin and smelled fuel.pulled over and there was fuel sprayed everywhere.the spigot had simply popped out of the housing!!! very close call.
    Jan 2013
    Geelong
    511
    Thanks JW. The priming handle on the Dauphine is non-functional so I'm considering a new pump but will strip it down 1st as I see primer return springs are available as a spare ergo it's obviously a common fault?
    Decades ago, I bought a 1964 Beetle for parts.
    Engine fire.
    The brass spigot on the "blow" side of the pump came out & sprayed fuel up. Sparks from the from the generator commutator & brushes did the rest. I always grab them (and the one at the carb) with multi-grips & try to pull them out. If they came out they went back in with a thin layer of Araldite. I like the idea of burring it 1st. Thanks!
    I was also anal about replacing the cover on the gen. brushes inspection ports.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Ipswich, Queensland.
    1,891
    Once the brass spigot is refitted, a little Loctite 290 Super Wick in around it will creep in and seal as well as prevent it falling out. Great on racecars and old single motorcycle bolts as well. You don't have to disassemble the parts, only put on the end of the thread and it will creep in and prevent the nut from undoing. The nut can still be undone with standard tools later.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    10,754
    Thanks Alan. I must buy some!
    Hope all's well over there.
    Renault 4CV 1951
    Renault R8 1965
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,017
    Heres some info on the Loctite 290 Alan suggested. Loctite ģ 290? Threadlocker - Henkel
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
