Dauphine Accelerator Cable Removal
Results 1 to 3 of 3
  • 1 Post By Simon
Thread: Dauphine Accelerator Cable Removal
    Jan 2013
    Geelong
    560
    Default Dauphine Accelerator Cable Removal
    Dauphine Accelerator Cable Removal-img_0619.jpgDetaching from carb is simplicity itself but how is the outer held in its yoke??
    I've put some real grunt trying to pull it from its yoke by hand but it won't shift.
    Is there a secret circlip in there??
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility
    1962 Renault Dauphine Gordini
    1950 Grey Fergie Tractor (Pending Resto Project)
    Simon's Avatar
    6,203
    The ferrule on the end of the outer cable has serrations that seat inside of the retaining bracket. Over time and given certain conditions, the ferrule will rust onto the bracket.
    Try popping the rubber cover off the end of the ferrule to see what you are dealing with, apply penetrant, and also see if manupulating the split in the bracket releases the ferrule. The ferrule pushes out towards the front of the car.
    geodon likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    11,233
    Quote Originally Posted by geodon View Post
ID:	62803Detaching from carb is simplicity itself but how is the outer held in its yoke??
    Why remove it? Is it sticky and in need of replacement? Agree with Simon re approach to removal - they are pressed in lightly.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
