R8/R10 cylinder head studs.
Results 1 to 9 of 9
    1000+ Posts Frans's Avatar
    Auckland
    1,491
    Default R8/R10 cylinder head studs.
    Hi all,
    Has anybody seen studs for the manifolds available that is a reducing stud? M10/M8 studs. M10 to screw into the head after a thread repair and then return to M8 for the nuts that pull the manifolds up to the gasket. Or is it something that I will have to make?
    Regards'
    Frans.
    Old enough to know better
    Young enough to do it anyway.
    19,050
    Hi all,
    Regards'
    Frans.
    Something like this ?
    ONLINE SALES Engine & Kart Part Catalogue
    Also available of ebay but at greater cost.
    Auckland
    1,491
    Thanks Robmac, spot on. I will place my order with them.
    Regards
    Frans.
    Newcastle
    2,592
    HI Frans,
    The studs you want are also used on the 1800-2000 cc aircooled VW motors for the exhaust. Probably some around over there.
    Cheers Jaahn
    10,763
    Regards
    Frans.
    Spot on indeed. Thanks again Robmac! I'd never seen that site.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,644
    Hi Frans,
    I have been using Heli-coils for years, with great sucess. But there comes a time when the base material is so damaged that it will not take a Heli-coil. When I was overseas I was shown another helper, known as a Keysert. They were fantastic for fixing damaged threads in Aluminium, and were very durable.
    Thread Repair , Helical Inserts, Keyserts, Keenserts | Keysert Range Kits | Buy Rivets | Rivet tools - Rivet Nuts & Other Specialty Fasteners
    I realise the stepped stud is a good fix, but I believe a repaired and restored thread is better.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Auckland
    1,491
    Hi ray,
    I have been using a similar insert but the one that cuts its own threads. I am building another motor (the dry sump one) and the head I have sourced has been abused liked almost all heads nowadays. The extractor side studs looks like craters and the smallest thread that I could cut is M14. An insert of M14 gives you stud size of M10. That is why I need the reducing studs.
    I hope you're keeping well and I just had Harry over here for a visit.
    Regards.
    Frans
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,020
    Frans
    Have you thought about drilling the damage holes and then either mig or tig up the holes and then machine flat and then redrill back to standard size.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Newcastle
    2,592
    Default A good supplier of inserts of interesting types !!
    Hi
    Here is a local supplier, to me in Newcastle, who I have used in previous times. Crosstools; Home
    Various types of thread inserts for all occasions, taps of all types, lefthand drills, TC bits, etc etc. They also supplied cheap parts boxes and other usefull stuff, before the internet made it easier. I see now they have diversified a bit.
    They also had a newsletter with heaps of good information and tips on new stuff and amusing wall charts of odd engineering impossibilities that was always good to get a laugh. I have some put away somewhere ?? I might look at their current newsletters to see if they still have a laugh on them.
    Cheers jaahn
