Douvrin - Fuego distributor rebuild
Results 1 to 2 of 2
    Oct 2005
    vic
    848
    Default Douvrin - Fuego distributor rebuild
    Did a less than stellar Rob-Roy climb in the Fuego.
    Ran great up there and then @#q*&%t!
    50 second climb.
    Fellow club member R4 bettered the time.
    Woe is car.
    Final fix (after first changing plugs and then running out crap fuel) was a distributor rebuild.
    Having sourced a cap from England and a rotor locally, the internals were looked at.
    Shaft had more than 3/4 of a mm play at the top bush.
    Machined out original bush and installed a needle roller bearing.
    Was going to put in a sintered bush but had this at the right price.
    Douvrin - Fuego distributor rebuild-b1.jpgDouvrin - Fuego distributor rebuild-s1.jpgDouvrin - Fuego distributor rebuild-d1.jpg
    Beast runs sweetly again ie will pull well past 6.
    Would recommend bush inspection when replacing cap/rotor.
    On with continual development!
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Good to hear it's sorted. Rob Roy doesn't like Fuego's.
    Last time I took the Fuego up, it had a boost control issue that resulted in the wastegate staying closed. It was quite sphincter tightening (and slow) crossing the finish line while wheelspinning at 100km/h.
