Renault 12 mastre cylinders
    Oct 2011
    39
    Default Renault 12 mastre cylinders
    Just looking through ebay for a new master cylinder for my r12 there's a few different variations in cylinder design. Has anyone tried differnt cylinders and gotten differnt performance? i was looking at this one off a scenic, it appears to have the same design as the cylinder on my 12, (easy to fit the pipes) what is the best cylinder to use?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,072
    Quote Originally Posted by Rory View Post
    The best to use is the same type that you are replacing.
    Remember bore size needs to be the same or you will change the pedal stroke.
    there is about 4 different master cylinders for the R12 depending on the year it was made.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Boonah Qld
    2,538
    While I am not sure of this; the Scenic may have metric thread and the R12 imperial.
    Brisbane/Australia
    2,067
    Remember the Scenic is designed for ABS so might not be the best thing to use.
    Why change anyway, R12 master cylinders aren't that hard to find and all my R12's stopped okay.
    If you want to increase your braking put in a wagon rear axle with the bigger drums.
    More brake pad area is better then pressing harder on the existing brake pads.
    Go too far and you'll get brakes that are on or off and not much in between.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,072
    Again it depends on the year, the virage (last of the R12 range) had metric at the master cylinder and imperial at the wheels.
    Regards Col
    1973 Alpine A110
