Renault 10 brake line
Results 1 to 9 of 9
    Sep 2011
    Victoria
    47
    Default Renault 10 brake line
    Just removed rubber line from master cylinder to just under drivers side wheel arch which in turn connects to the brake fluid bottle
    Does anyone have one or know who should or can this be replaced with any rubber hose from Clark rubber
    Fellow Frogger! bingham driver's Avatar
    Jan 2011
    Myers Flat
    182
    Hi & welcome, rubber fuel/powersteering or auto-trans hose!
    Once I thought I was wrong but, I was mistaken
    Sep 2011
    Victoria
    47
    Rubber tube that runs off off brake master cylinder up to the floor then joins the tube to brake fluid bottle in front boot
    Traralgon,Victoria
    207
    I replaced mine with hose from Repco,good idea to take a sample of the old hose with you.
    Sep 2011
    Victoria
    47
    Thanks all done
    640
    I thought it was a steel tube similar to the R8?
    If you have it out, take it Superstop Brakes at 727 Whitehorse Rd, Mont Albert VIC 3127 and they will make one for you using the original as a template if originality is important to you.
    Angelo
    4,377
    Angelo - it is steel but there are two rubber hoses where it passes through the scuttle panel and boot floor.
    KB
    640
    Oh is that all screwg1 is after, Bursons or Repco can easily help out.
    i misunderstood!
    thanks KB
    Ipswich, Queensland.
    1,898
    Don't use fuel line as the brake fluid will sweat through it over a period. VW beetles and other early models use a special braided rubber hose. A VW specialist should keep this. BMW 2002s also use the same type hose.
