My Scenic is Singing?
Results 1 to 2 of 2
    Dec 2004
    VICTORIA
    83
    Default My Scenic is Singing?
    Hi:
    About 15,000km ago I replaced all the belts and pulleys and recently replaced the tensioner pulley. Not long ago the fan belt started to sing- quite an awful melody and very high pitched. I brought some belt spray and it stopped the squeal for two days now it's back worse than ever. It's the belt not the pulleys. Is it a matter of buying another new belt and do some belts make more noise than others?
    Thanks for any help you can give me.
    cheers
    Geoff
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,043
    It would be most remarkable that a belt could make such a racket on it's own. To verify this, remove the belt, place it in a quiet area and listen carefully for a few minutes. If the awful melody is not apparent, suspect that somehow it's interaction with the pulleys may be the cause.
